OT Truck Problems OT
Barbara Gill, Remlik VA
>I went out this morning to start my Dodge truck and the key will not rotate to start the truck. I have wiggled the steering wheel to make sure it has set, removed and replaced the key, and tried twisting the key a number of times to no avail. It will rotate back one click but not forward. Any suggestions?
Re: OT Truck Problems OT
Jesper, Denmark
Jesper, Denmark
>Try another key if you have one.
Richard T Jones
>B,
Turning the key back doesn't usually necessitate unlocking the column, so it could be you need to muscle that steering wheel just a bit more to get the key to turn. I wouldn't force the key, but just keep a small amount of pressure on it while you pull on the wheel.
Good luck.
Rich
>I will try both suggestions. It worked just fine yesterday.
Carole Valentine
>Sounds like you need to fiddle with the steering wheel some more. Apply the brakes at the same time you are messing with the wheel. Don't know why, but this works on my Explorer on the rare occasion that that happens. Whatever you do, don't put too much pressure on the key. If it breaks off, you will have even bigger problems.
>Barb They put too much safety crap on the cars today. There are several things that may affect the key. You tried the steering column. Jiggle it and the key and see if that works.
The shifter position can affect the key. Move it in and out of park or try neutral. If it's a manual tranny it could be the clutch. It hs a switch also.
The brake on many cars has a switch that must be actuated and can affect the starting.
On my Mercury there are little plastic pads that sit on these switches. One fell off and the other was worn. Being a woodturner I simply turned some wooden pads that were thick enough to activate the switches.
On my Toyota truck there are 3 different things that work with the Auto shift lever. It was a pain in the butt to get all of them working properly when I had to replace one of the parts.
I won't rant on why all of our cars have all of this crap but it makes it very hard to work on them, especially if you away from home and don't have a meter and all the special tools it now takes.
My Friends Volkswagen just stopped for no reason on the interstate. He called because I was the closest person. We fiddled with it for 2 hours in the rain. It finally started on it's own. Some strange electrical problem I'm sure. Now he's afraid to drive it anywhere.
Fixed
>I held pressure on the wheel while trying the key. All is fine now. Thanks.
Re: Fixed
Gary Evans Tallassee, TN
>Hi Barb,
What happens at times is that we stop the vehicle with the wheels turned slightly. As the key is turned off and the steering wheel lock actuates, the locking mechanism has a little side pressure applied to it because the steering wheel wants to go a little farther before it rests.
You got the right fix. Sometimes it takes a little extra pressure on the steering wheel to overcome the side pressure on the lock, sometimes it takes a lot.
Gary
Re: Fixed
Bill Hale / The Wood Spinner
>This is the most common fix. Sometimes it takes a lot of pressure on the wheels. Glad you got it!
Bill in CG, AZ
I Always Say
Ken Oakley-Sunny St. Cloud, Fla.
>If it doesn't fit, get a bigger hammer !!
Re: I Always Say
Bill Turpin in WNC mountains
>If this happens on a fairly steep hill, it takes even more pressure!
Jerry Whitaker
>Get a Ford
Re: Blasphemy!!! :)
Allen Neighbors
Whats on your ring?
Dustmaker Mike
>A friend of mine had a problem sort of like you had. When I went to look at it I noticed she had about a pound of junk hanging on her eky ring. If you think about it all that weight sits on the little fingers in the key tumbler causeing a lot of wear and tear on the tumbler and just think if you hit a lot of bumps it just messes up the tumbler all the more. I only keep the key and the thob on my rings. She had to have the lock cylinder replaced on her car to get it working right again. Just a thought.
Re: Whats on your ring?
Allen Neighbors
>I agree, Mike, my daughter in law had to replace her ignition switch also, because of too much junk hanging on the switch. It cost her a mint. The Service Manager told her to lighten the load on her key ring.
Your friends VW
Steven Kubien
>Hey John,
We had a Golf for a while. If we running warm/hot for a long period of time (think 100-120 km/h for a few hours) and we pulled off at a service station, it wouldn't start again. We would have wait for an hour +, with the hood open while it cooled before it would think of turning over. We were told by a VW mechanic that there was some sensor in it to stop people from over-heating the engine and damaging it. It never cut out while the engine was running though. Man, I hated that car.
Steve Kubien
near death by key riing
JohnKJordan in East TN
>>... she had about a pound of junk hanging on her key ring.
Reminds me of a near disaster I had in a Fiat 'bout 35 years ago. I can look back and laugh now.
I had removed the plastic housing on the steering wheel that morning to replace the ignition switch. My key ring also had huge gob of keys, some of which were fastened to the main keyring with a thin twisted piece of wire. (The gob of keys probably caused the ignition switch failure in the first place.) I had paper trash on the floor for as part of my campaign for president of the Slob of the Month Club.
Grooving down the interstate in heavy traffic the key gob somehow swung into and shorted against some exposed wiring, heating the wire until it burned in two. The red hot wire and half the keys dropped and set the papers on the floorboard on fire.
There I was, trying to get over to the side of the interstate while stomping at the fire on the floor. The things I did for fun back then.
Like me, but John, that is why we are so wise.
henthorn
Re: Blasphemy!!! :)
Jerry Whitaker
>OUCH!!!
>LOL Mike. there are only 3 keys on my keyring. I am not the typical female. Back when I started carrying a diaper bag I stopped carrying a purse and never looked back. My keys have to fit neatly into my pocket or Dan's depending upon where I am.
It was just a positional fluke apparently. We don't have steep hills around here except maybe where the old prehistoric river banks are or the guts down to the creeks. I had the truck backed up to the house so I could unload firewood.
get a Toyota-Made in Kentucky now
