THE WOODRAT IS BACK!
home made John Jordan tools
>Here is my set of John Jordan style tools. I have a couple that he doesn't have. That's probably because I'm not as good a turner as he is. The top one is my latest. It is designed to let me get into a hollow vessel with an almost flat top. I couldn't do that with the other tools.
These are all 1/2" bars with 3/4" adaptors on the tail end. 2 of them have glued in inserts. The rest have set screws so they will take the #1 hunter tool with the 3/16" square bar.
Re: home made John Jordan tools
close up detail
>I put the set screws on the bottom which sometimes get in the way when inserting the tool in the hole of the piece but I find it doesn't get clogged with shaving this way and works out better for me. I could probably just order shorter set screws or gring them down but it hasn't been that big a problem.
Mike Stafford
Re: close up detail
Mike Stafford
>So when is the John Lucas line of tools hitting the market? They look great, a bit like instruments of medieval torture but great nevertheless......
Re: close up detail
>Mike That's a great description. Maybe I should have been a surgeon. How about a dentist. I believe I could lever a tooth out pretty fast with one of those tools.
Steven Antonucci
Something I also just figured out!
steve antonucci
>I just started making the set screw on the bottom for the exact same reason. I use the compressor to blow it out on the older tools where it's on the top vs. picking it out with a nail (old school). I don't know how I ever lived without a compressor?
For any aspiring tool makes, I'd also offer the following advice. I think John is using cold rolled from the BORG, which is where I started as well. In a pinch, I'll still use it, but I prefer to order O1 from Enco (pick your favorite outlet...) because it doesn't turn your hands black when turning wet wood. Cold rolled does. Not the biggest problem in the world, but it's only a few $$$ more for O1, and it also makes a much prettier tool. (I'm sure there are other steels that Enco sells that are equally as pretty, I'm just not experienced with them.)
Steven
Cyril Griesbach
>OK folks, I'm considering doing some of this tool making myself so here is my question and I'd guess others might be interested also.
What kind of tools and equipment do you have in your shops to make these and other tools? What would be the minimum tools and equipment needed to do this?
Re: Something I also just figured out!
>Steve Not bad advice. I just spray mine with lacquer. It wears off the bottom but hasn't caused me any problems.
I too don't see how I got along without a compressor. Now I'm trying to convince myself that I can't get along without a really big compressor.
>It depends on what tools you want to make. I made a lot of tools with nothing but hand tools before I stepped up to the Smithy. I should probably do an article on this. I think a drill press is probably really handy but in some cases accuracy isn't that important.
A good vise is really important. You can do a lot of drilling, filing, hacksawing and shaping with a good vice.
A MAPP gas torch is handy if you want to do any bending but it's a real pain to heat up anything bigger than 3/8". I heat and bend 1/2" bar but you can only heat about 1/2" at a time so it takes forever to bend one of the John Jordan tools.
You'll probably need a tap and handle. I use 1/4" x 28 for most of my tools because it takes very little metal for it to hold.
A good file is handy although you can do a lot of work with a belt sander or grinder.
For cutting metal, I have done it by hand with a hacksaw but 3/1/2" grinder with cut off disc is much quicker.
To make the ornament hollowing tools all you need is MAPP gas torch, vise and hacksaw.
I once built a Lyle Jamieson style boring bar with nothing but a vise, drill press,hacksaw and files. No welder or oxyacetylene. It was all assembled with All-thread rod, 3/4" cold roll, steel sleeves, roll pins and some set screws.
I'll be glad to try and explain how I would build a certain tool with whatever tools you have. It surprising what you can build if time isn't an issue.
Re: Adaptor Question
Steve in NC
>John
Very nice work on the tools. Did you make the 1/2 x 3/4 adaptors or can you purchase them.
Happy New Year to All
Steve
georgetroy
>I have many similar tools purchased from John Jordan and others. On almost all the hollowing tools I use out riggers from BCT these will fit 1/2 or 5/8 shanks. Outriggers are great for resisting torque and a must have for my arthritics. Outrigger angles can be set exactly where you want the tool tip to cut. I will also use heavy handles where ever possible. The next best thing for torque resistors is vice grips clamped over masking tape to reduce marking shanks. I have 2 sizes of vise grips which works for me. I avoid metal working in my shop, the danger of fire is just too great. I take it outside. GT
>I made mine. Craft Supplies sells the Hosaluk handle inserts that come in different sizes. They are kind of pricey but you only really need one. I put them on all of my tools. If I had been thinking I would have just made one adaptor handle to hold the 1/2" tools.
Allen Neighbors
>Good job, John; some of those look like they came off my tool rack. Though I wasn't smart enough to put the set screws on the bottom. Now I use the air gun for a little blast of air after I'm finished with the tool, or before I have to sharpen the cutters.
I got all my ideas for tools from Darrell Feltmate's pages, and just modified them to fit.
You and Darrell are two of my most favorite people! Thanks for posting!
