Liquid masking for airbrushing
>I've never used the liquid masking before and I'm having trouble. I don't have a way to spray it on so I've been doing some tests with brushing. It sticks to the wood to well and I have a lot of trouble peeling it off. I've only sanded the wood on the test pieces. The masking material is water based so I raised the grain on the wood and then sanded lightly. The mask still stuck to the wood so that I can only get it off in little pieces.
When I took Binh Pho's class I don't remember having any problems but we sprayed it on. Do I need a thicker mask? Should I seal the wood? If I seal it I won't be able to use dyes which is OK on this project because I'm using paint but I would like to know.
Re: Liquid masking for airbrushing
Phil Joines Krum, Tx
>I haven't used the mask but one of the little Preval sprayers from an auto paint supplier should work and they're cheep.
>I've been buying the HF touch up guns. Right now I have one dedicated to Lacquer. don't want to mess it up so I might just buy another one. I don't know if they will handle the Masking fluid, it's thicker. I've looked at the sprayer known as "The Critter". I think that's what Binh Used but they've gone up in price and now run about $50 or $60 bucks. If I seriously get into this it would pay for itself but right now that's a lot of money for a one time use.
Darryl
>John The Critter is on amazon for $39. I have sprayed latex paint with it although I usually use it for lacquer. The best thing about it is that you can put some acetone in a jar and clean up lacquer or use water for water based stuff. Easy to use. the only down side is that you can not adjust the spray pattern it is always circular but unless you are real fussy with you painting it does not matter.
>Thanks Daryl I never thought of Looking on Amazon.
Stephen Mushinski
>John,
You must seal the wood before you spray the mask. I am not sure what Binh uses but Frank Sudol sealed the wood with lacquer sanding sealer. I have used just spray can lacquers without any problem. Brushing or spraying shouldn't not make a difference.
Hope this helps,
Steve
