THE WOODRAT IS BACK!
THE END
THE END
THE END
eaglesc
>Trying out a lens for my new used Kodak camera.
Re: THE END
Re: THE END
>I look at a lot of stuff here and think, "I see how they did that, I could do it if I tried." I look at your stuff and have no clue as to how you did it or where I would start if I wanted to. I like it. Thanks for posting. Maybe some time you could post something like a tutorial. I doubt I will try even knowing how, but it is a matter of curiosity for me.
Re: THE END
Re: THE END
>I agree with Barry. I would have to hold one of your pens in my hand to even begin to figure out how it was done. They are exceptional.
Looks like you have good macro capability with that lens. You have almost no depth of field at that setting which is common at high magnifications. You can see the sharpness falling off at the edges. If that is the end of one of your pens I'd say you have about 2mm of sharpness. If you end up shooting that close stop the lens down as far as it will go. Of course as long as the subject is relatively flat as in your photo it works great.
Re: THE END
still stumped
JohnKJordan in East TN
>As I mentioned before, I was also mystified.
Looking at this end picture, I can imagine how to make an inlay that is STRAIGHT down the blank, but not serpentine: Cut a series of thin groves into a solid blank and glue a thin strip into each groove before the next groove is cut. Each strip could be a laminate.
Overlapping the grooves could explain the apparent over/under effect, but does not explain the curvature of each strip! Some way to cut a precision serpentine grove? (hard to imagine how) I'm still stumped.
But yikes, what a lot of work!
Re: THE END
Steven Antonucci
Small router bit in a jig to cut the grooves?
steve antonucci
>I think I get how you do it, but I'm not 100%. Amazing process, no doubt.
Steve
Re: THE END
Re: still stumped
eaglesc
>"Overlapping the grooves could explain the apparent over/under effect, "
There are 24 "stripes" of pattern or "waves" if you will in this red and white version of the original picture.
To be honest I don't know how I Do it either
Re: THE END
Re: still stumped
Wonderful! That made me laugh out loud!
I remember when you posted the red and white striped one a few months ago, fountain pen, opened. I saved a copy in my inspiration/pens_eaglesc folder.
Re: THE END
Re: Small router bit in a jig to cut the grooves?
Mark Williamson
>WOW! I have never seen anything like that! That is REALLY awesome! "I don't know how I do it!" HA! What a crock! LOL Your just keeping your secrets to yourself!!! he he
Great work!
Re: THE END
eaglesc
>Yes I know how I "do it" a monkey could make this it is so simple.
I don't know HOW the multiple patterns achieve the interweaving.
I sat down and TRIED to make a design that appeared woven in a round form and gave up.
I continued on with what I was doing and the "weave" appeared.
I chalk it up to Divine intervention but still do not understand why it happens.
Re: THE END
MWWoodWorks
>He He!
Did I get the wrong impression in that you are selling your blanks? I would love to turn some miniatures from some of them! : ) Do you ever have any cut-offs that you would be willing to part with? What's the secret? You can tell me, I won't tell anyone! : )
All in all, great effect!
Re: THE END
eaglesc
>There are some off cuts at times and I save them normally.
Some times while parting them(I don't cut them with a saw too much waste, I use a parting tool made from a table knife, it 's thinner) I turn it into a bead and give it to my wife, she saves those in a little tin box.Maybe someday we'll have enough to string for a garland for the Christmas tree
Re: THE END
MWWoodWorks
>You�re not budging on that secret! LOL Good luck with the garland! That�s going to be a lot of beads! I know, perhaps you could send ME a few blanks and I could help you turn some beads!!!!
I know, it's not going to happen! LOL (You can't blame a guy for tryin'?!)
Oh well, if you ever write the book on it, you know I will buy one! :)
Just out of curiosity, DOES anyone out here make there own unique pen blanks that are up for purchase? If so, feel free to email me!
Re: THE END
Steven Antonucci
The thinnest parting tool- almost no waste...
steve antonucci
>I use an Xacto knife razor saw blade. It's a small backsaw, and they sell them at craft stores with a red handle and two blades. I just hole it vertically on the blank and it cuts a kerf probably around 1/100" (and cleanly if you keep the blade straight and clean).
Steve
Re: THE END
Re: THE END
David Breth
>Saw your post and couldn't help but be reminded of what I made my daughter for Christmas a few years ago.
David B.
Re: THE END
Re: The thinnest parting tool- almost no waste...
eaglesc
>I have used the same saw but it dawned on me that the wood keeps hitting the same teeth.
The blade is thicker than the size you posted but thinner than my table knife.
I also use the table knife because it is cheaper than the exacto saw.
Another method I Have used it a scroll saw blade with vise grips.
there is a convoluted way of positioning the blade in the vise grips and holding it on its side on the tool rest.
I switched to the table knife because sometimes I am cutting blanks with metal in them. The knife is resharpenable.
