Open end wrenches
Open end wrenches
Open end wrenches
Bill Crommett
>Some of you turners have used a specially ground open end wrench to make standard and consistent spigots. Could someone tell me how the wrenches were ground to give a good cutting edge.
Re: Open end wrenches
Jim Shaver Oakville, Ontario
>Hi Bill,
I have a 1/2" box wrench that I hollow ground the edge of one side, and sharpened like a chisel on a stone, I flattened the underside of that side with a diamond stone to develop a cutting edge. Works great.
Take care,
Jim
>I tried the ground open end wrench. I find it better to use a parting tool with the open end wrench on the backside. When the parting tool cuts deep enough the wrench drops over. You do need a wrench that is about the same thickness as your parting tool or you can make several passes with the parting tool.
I also use a dial caliper. You can set that to any size and then use the parting tool to cut down to that size. This has the advantage of making the tenon fit whatever hole you drilled or bored.
BobM
>Would you post a picture of this wrench grind you are talking about so we can understand it better.
>Here is my "fat 3/8" tenon cutter. I used a 10mm wrench. When sharpened it cuts a tenon that is .020" too thick. I use this when I use my 3/8" twist drill which produces a hole in wood that is slightly loose on a 3/8" tenon. Since I make my production mirror handles 3/8" I have a wrench a drill bit dedicated to this product. The wrench is a standard 3/8" open end that has not been sharpened. I use a parting tool to make the cut and the wrench to check the size.
Here is a photo of the 10mm wrench. Notice the top jaw has been sharpened. I use a diamond hone on the top only, after the initial sharpening. I ground the bottom jaw round on the leading edge and reduced the sides of the bottom jaw so it's narrower than the top jaw.
To use it you have to think backwards. If you push down on the top to make the cut like you do a parting tool it will just keep on cutting until your tenon is too small. You have to push in but put the pressure on the bottom jaw. This will let the top jaw stop cutting when the tenon is the proper size. It does work. I just find that I have better control when I use the other method. Perhaps if I used it a few hundred times I would be more comfortable with this method.
If I was going to make a 3/8" wrench cutter I would probably start with 9mm and then open it up to the correct size with diamond hones and a dremel. The first one I made I took a 3/8" wrench that measures to be a little over 3/8". Then I heated it and squashed it a little. Then I reground it to produce the exact tenon thickness that I wanted. I have no idea what happened to that wrench. It's probably in the same place my socks go when they leave the washing machine. I think there's a worm hole there that transports things to another universe. I'm pretty sure they are going to find a planet made entirely of lost items from Earth.
OK, Lunch is over. Back to work.
Bill Crommett
>Jim : Could you be more specific ? Which jaw, which side? Where is the hollow grinding done ? Have you got a picture ?
Bill
Illustration of Mine
>Hi Bill,
My shop is closed up for the winter and I am not sure just where it is quickly to make an image for you.
I drew this out to give you an idea of what it looks like. It was an inexpensive tool that I bought at Canadian Tire, the cutting edge is easily sharpened with a diamond hone. I use it to make sized tenons for furniture work where I need some accuracy such as when I am making drawer pulls.
Photobucket
I know I have a 3/8" and a 1/2" out in the shop. I use them much the same way that some people use a bedan with a sizing attachment.
Hope the illustration helps a bit.
Take care,
Jim
Re: Illustration of Mine
Carol - now in NC Nebraska
>Thanks, Jim.
I like that idea. I have a couple of old wrenches back home that may be redirected to this function.
So the idea is to keep the bottom jaw of the wrench against the bottom side of the tenon and tilt the top into the wood until there is nothing left to cut and you are left with the properly sized tenon. Is this right?
>Yes Carol,
That is exactly what I do with the tool.
Take care,
Jim
>Great drawing Jim, thanks. I may look at making one with the bottom jaw longer. That would make it easier to start the cut although I just push it in so both jaws touch and then keep the pressure on the bottom jaw. Hope your not too cold up there. It's 56 in my part of Tennessee today so the shop hasn't been too bad.
Open end wrenches **pic**
Ron in Drums PA
I grind the top edge.
This is the one I use for pen finials. I took a 2# hammer and closed the gap a bit until I had a perfect fit
Bill Crommett
>Thanks, Jim and Ron. I will get busy with the big grinder tomorrow. I don't dare start it up at 10:45 PM ANY night.
Good illustration, and a good pic.
Dave Peebles Lyons, Ohio!
>Hi Bill,
I spent about an hour last night looking for a pic I posted of mine. No Luck :(
But it looks very much like the one my friend Jim Shaver posted.
I first discovered the idea in an old Fine Woodworking article. I was doing Shaker chairs at the time and felt it was the perfect tool for turning the 5/8" tenons on many of the cross members on the chairs.
I found that if I bought the metric wrenches and did a little grinding I could get a perfect fit with little effort. The standard size 5'8" wrench was slightly oversized.
Maybe someone with better searching skills than I can find the original post I made, but I can not. :)
But it is a real time saver... at least for me...
Best wishes,
Dave
