Silacone solvent
Silacone solvent
Silacone solvent
Bill Crommett
>I have forgotten which one of you generous people suggested that because silicone smelled like vinegar that vinegar might be a solvent to get a broken goblet stub out of the turned wood stem. Because all the other info I could download spoke of industrial and highly toxic solvents, I thought that the vinegar would be worth a try. After three or four days of soaking the stub in a glass of vinegar, the stub came twisting out with a generous amount of goo attached. Thanks for the suggestion.
Re: Silacone solvent
Jim Pugh, Elyria, OH
>actually, it's the acetic acid in the vinegar that does the job. Next time go to a photo store and buy some there. It'll be much stronger and therefore faster than using the vinegar.
Jesper, Denmark
Re: Silicone solvent.....
Jesper, Denmark
>Bill, whatever it was that got the stem free, it was not the vinegar. Maybe just soaking in the water associated with the acetic acid in the vinegar.
The acetic acid is a byproduct of the curing of the silicone with water from the air. Acetic acid is not a solvent for cured silicone. Vinegar is just a solution of 5% acetic acid in water.
Bill Crommett
>Jesper : I know what the book says, and I know that the vinegar is weak acetic acid, but whatever it was, the vinegar softened up the silicone so I could separate the two pieces.
Like grandma used to say : "If a cow manure poultice works, use it" !
>I'll try to remember to run a test when I get back to work. I just happen to have some silicone and some acetic acid at work. Well actually it's Kodak stop bath, I don't remember if we still have the concentrated acetic acid. I've had to remove silicone before also and nothing short of digging it out worked.
Dennis in Southern Oregon
>John, it would be interesting of you would try your experiment with vinegar, and separately with plane water. Dennis
Brian Simmons, Heflin, AL
>from the ge website at:
http://www.geadvancedmaterials.com/geam/gesa/Residential/en/ProductSupport/FAQDetail/troubleshootingquestions.html
How do I remove silicone products?
It is VERY difficult to remove silicone from a surface. However, if you must remove it, follow the suggestions below.
To remove silicone sealant from surfaces, first remove as much as possible by cutting/peeling/scraping excess sealant from surface.
* For ceramic tile, marble, Formica>�>, fiberglass, etc., use 100% mineral spirits (turpentine) and a non-abrasive scouring pad. Test solvent on a hidden area of the surface to ensure that discoloration will not occur. If discoloration does occur, contact the manufacturer of the surface for further assistance.
* For glass surfaces, use a razor blade to remove as much as possible, then apply mineral spirits. Remove excess as much as possible, then apply mineral spirits. Remove excess with a towel or other suitable cleaning utensil that will not mar the surface (such as a non-abrasive pad).
NOTE: For surfaces such as hard plastics or painted surfaces, including cars, use rubbing alcohol and a soft cloth. Do not use mineral spirits. Only use these solvents in a well-ventilated area and follow all safety precautions and instructions listed on the product label. Material Safety Data Sheets for GE Sealants & Adhesives products are available upon request. Similar information for solvents and other chemicals you choose to use with GE products should be obtained from your suppliers. When solvents are used, proper safety precautions must be observed. On Rough, Porous Surfaces>
To remove sealant from a porous/rough surface, (concrete, brick, wallpaper) remove as much of the sealant as possible (same as smooth surface). If necessary, use a wire brush in conjunction with mineral spirits. NOTE: We do not recommend use of a wire brush to remove sealant from wood surfaces, as doing so could damage the wood. Also, mineral spirits should not be used if the wood has any type of finish on it. Test solvent on a hidden area before applying. Mineral spirits are flammable and should be used away from sparks, flames and other sources of ignition. Only use these solvents in a well-ventilated area and follow all safety precautions and instructions listed on the product label. Material Safety Data Sheets for GE Sealants & Adhesives products are available upon request. Similar information for solvents and other chemicals you choose to use with GE products should be obtained from your suppliers. When solvents are used, proper safety precautions must be observed. NOTE: There is nothing that will dissolve silicone. NOTE: If reapplying silicone to the area, remove the old sealant. Then clean the area with a disinfectant if mold or mildew is present, apply rubbing alcohol. Let the area dry before re-applying silicone.<> Do not use soap to clean surfaces to be sealed because silicone will not adhere to surfaces covered with any soap scum.
>also from a google search for "dissolves silicone"
http://forum.doityourself.com/showthread.php?t=209169
About removing silicone. Xylene dissolves silicone, and is readily available diluted in small containers under the trade name "Goof Off". WD-40 works too, and so does acetone (nail polish remover is diluted acetone if I'm not mistaken). Also, silicone based lubricants apparently soften normally firm... uh, silicone objects (all sorts of information when you Google ). You can buy patented silicone removers at the hardware store too.
and
there is a product from the UK called silicone-eater, it is made by Everbuild http://www.everbuild.co.uk/index.php
did not see this product for sale in the states though.
