>I think the thing I love most about woodturning is there no limit to the number of things one can learn about this hobby. I have been trying some new things of late. Among the new thing is chatterwork. I have tried it in the past with limited success but after some practice I have been able to get a few pieces that look almost halfway decent. This box in Goncalo alves is 2 3/8" in diameter and 3" tall. The second picture will show the chatterwork better. The chatterwork inlay is done in East Indian rosewood which I dyed with India ink.
>Nice job Mike. I've been trying to describe how to do chatterwork over on the Woodmagazine site. It's hard to describe in words. You seem to be getting it down. Someone is going to love that box.
I always enjoy reading your posts, you have a spirit of excitment and discovery in every new work. I like the expression of the design along with the chatter work enhancement.
Mike you work and spirit are a breath of fresh air, keep it up my friend.
>That is a beautiful box - such a nice finish, and such beautiful wood, treated well in your design.
I just tried a tiny bit of chatter work today on a teeny tiny spin top (my first) with no success. I'm encouraged by your persistence, and will try again.
>Carol, I recommend using dense woods for chatterwork and applying the cutter slightly downward while the piece is turning at a relatively high rpm. Lately I have been getting my best results at around 2200 but that could change with a new wood.
Thank you Ron, Jim, John and Joanne. I appreciate the feedback.
Joanne, I can assure you there was some of the "chatterwork" you were referring to while I was working on getting the variables right to achieve a decent result while chattering. That verbal "chatterwork" may not have been suitable for all audiences....
As always, your box hits all the right notes. Excellent work. Seeing this and yur other boxes almost makes me want to go back to boxes. But then, my nickname would have to be changed from bowlman to something else.
I admit to not being a big fan of chatterwork in general, but that is certainly nicely done. The shape is nice - is the top hollowed "square" or as a dome?
Is the rosewood insert also done on the end grain? Does end grain "chatter" better?
Another question: I roughed out a couple of cococbolo blanks for boxes yesterday. In his book "Turning Boxes", Raffan suggests roughing out even very dry blanks and letting them sit a while to relieve stresses before final turning. In the past I've let dry blanks sit for a day or two but perhaps that is overkill. Do you do this as well, and if so, how do you decide how long to wait?
>John, I am hardly an expert at chatterwork but here are the best answers I can give at this time.
To your first question, as it turns out on this piece the box recess is hollowed out slightly dome shaped because I undercut the piece of chatterwork when I parted if off the blank. I felt it best to support the insert as completely as possible as it is very thin; only slightly more than 1/16" thick.
Yes, this insert with chatterwork was definitely done on end grain. I think chatterwork is best done on end grain although I think it can be done less successfully on side grain. I think the degree of success one can achieve is determined by how hard the wood is. Chatterwork on soft end grain is a mess. I speak from experience there because when I was practicing I found out very quickly that soft maple, although a hard wood was not hard enough for distinct chatterwork markings. Someone with more experience may be able to teach us both something about that.
I do rough out boxes and let them sit. If I have an idea for a piece of wood I will roughly shape and hollow it a little. Then I will tape the pieces together just as Mr. Raffan shows in his book. Usually I will write on the tape something that will remind me of the shape I had in mind when I roughed the blank. If it is green or air dried wood I will rough them out, soak the two halves in an alcohol bath and then tape them together with the open ends out to dry much like a bowl blank. After letting them sit in the shop for a while I will place them in the hot water heater closet to sit for a month or two. Letting the wood equilibrate is a good idea to allow for moisture/humidity changes and wood stresses.
If the wood is dry I just turn the box in one session if I can. Usually that is possible if the finishing is cooperating.
