Royal palm
Royal palm
Royal palm
Bill Crommett
>A friend who has in the past supplied me with many samples of turning wood, brought me from Florida a well sealed chunk of Royal Palm. My question is: Can this be turned, and is it worthwhile to try ?
Re: Royal palm
Steven Antonucci
T'aint easy... but it's pretty stuff
steve antonucci
>kind of like a pile of steel needles encases in jello. Very fibrous with a tendency to splinter. Pretty if you've got sharp tools and patience.
Steve
Re: Royal palm
Re: Royal palm
Cyril Griesbach
>Bill, I have no experience with it but some years ago I talked to a guy in Florida who turned Palm and he said it can bring on a whole new low in one's vocabulary. He did also say that sharp tools and a slicing technique worked for him.
Re: Royal palm
Re: Royal palm
Ed McDonnell
>It is very worth turning. The degree of difficulty will be correlated to where exactly the "wood" came from in the tree. The closer to the center the more problematic. The outer couple inches of the tree give the best "wood". The middle of the tree is worthless for turning.
If the wood is wet, I would either turn it quick or remove any wood sealer to let it dry. Keep airflow all around it. Palm is loaded with something (sugars?) that the fungus / bacteria love. Spalted palm is not attractive. I generally sticker my blanks and set them out in the sun to dry, turning them over once a day. I also use a microwave to aggressively force dry palm blanks and they hold up very well.
Palm has a bad reputation for being tough to turn. As mentioned above, sharp tools, shear cuts and patience solve a lot of the problems. If all else fails, break out the 80 grit gouge. It sands easily and problems left over from turning are quickly erased.
Ed
Re: Royal palm
Re: Royal palm
Bill Crommett
>Thank you Steve, Cyril, and Ed. I will give it a try when I get the Christmas demands finished.
