Re: Who would have figured
Fog Tanner
>I have cored a number of 22-23" blanks on my Vic 300 and know what you mean. I could only core about 12"-13" on my 16" Delta.
I keep the belt a little bit looser than normal when I core. It is in low range and the RPM is half way between the high and low. I was told this is where the motor makes the most power and it works so far - works out to about 600-800 rpm depeneding on which lathe I use.
While I did not "stall" the lathe, I have stopped the piece a couple of times - reason for the loose belt, no bent tools. After looking closely I noticed that I had used the wrong knife for the size I was trying to cut. I was able to make it work by opening the kerf up to about twice the width. I also had been using the square cut blades, even after a day with Mike Mahoney. After the second time of stopping, I reground the tool like Mike does and that seemed to cure the problems. I also found that I needed to clean the blades fairly regularly and use Pam to lube the knife and tool rest. This helps keep the knives moving freely.
Also on some woods like Mesquite, when you get to the point in the cut where you are "going around the bend" - the wood will want to pull the knife into the cut too quickly and cause a stall or twisted blade. At this point I am typically pulling back in the handle and not pushing. I have known a couple of guys who twisted their blades up when they didn't pull back. They also kept their belts tight too.
I have since bought the micro or smaller blades which is for the 10" and under size. These are shorter knives and will fit in the smaller radius. You can also get a few more bowls with them if you like the 3"-4" size.
Fog
