A different way...
A different way...
Keith Tompkins
A different way...
Keith Tompkins
>To use a skew chisel. Top image shows the view looking down on the skew cutting a sphere, the second image shows the tool position from the side view.
There are several advantages of using a skew this way: I can see the cut at all times, the tool doesn't obscure the cut. The tool is held on the same plane at all times...no need to cut, roll the tool, and lift the handle at the same time. All I need to do is use body language to steer the tool where I want it to go, while riding the bevel. The red star shows where the tool is cutting...right on the center line. I can cut at any point along the edge without fear of the long point catching. By cutting on center, I have complete access to the turning...right to the center. Catches are minimized because there is no wood under the tool to pull the tool deeper and deeper into the cut. The skew angle creates a natural shear angle to cleanly peel wood away, even on end grain. This cut can be done with the long point up as well, but is trickier to master. I do use the skew in the conventional manner as well, but favor this method for many cuts.
I haven't had much time lately, but Merry Christmas to all!
Re: A different way...
keith zimmerman, Normal IL
>Is this cut only for spheres, or can it be used on other forms. I generally use the skew with the long point down when paring, but the cut is about midway between the point and the center of the edge. Wouldn't it be easy to get a catch because of the location on the edge where the cut is being made?
keithz
Ken Grunke from SW WI
>Keith, you told me about this technique here about a year ago, when I asked about turning small beads. I do use it now and then and it really is a good alternative. I was turning a round-bottomed cup today and with the short point of my 1" skew I came close to a kickback. So I reached for my 1/2" flat skew which is perfect for this because the handle is short and easy to swing around.
Also, you can look straight down at the cut which is probably the biggest advantage.
Thanks for sharing this.
Allen Neighbors
>My half-inch flat skew is my favorite skew. Thanks for sharing this technique, I'll give it a try later today. (That is, if I can get the old pot bellied stove in my shop to raise the temp above 35F.)
Dusting of light snow on the ground in Childress, TX.
Keith Tompkins
Keith Tompkins
>HI Keith, I use it for almost anything that can be turned with a skew, especially beads and deep cuts. By riding the bevel catches are very rare, and I can use most of the cutting edge by adjusting my toolrest height.
