Re: Spinning Tops
JohnKJordan in East TN
>>...what is the secret?
Psst, can you keep a secret? So can I. (Sorry, old joke.)
I've made many hundreds of finger tops and have had some very good spinners, but I've never timed them or tried to analyze. I tend to go for interesting form and pretty wood rather than for long life. Kids of all ages love them. The picture attached below shows some from a few years ago.
(BTW, for those who haven't turned tops, all of mine are turned with the blank in a chuck - turn and finish the body at the end of the blank before turning the handle, support the top with the left hand if necessary to prevent vibration when the handle gets very thin, then part off with the skew and touch up the top of the handle by hand. I usually use a fairly long blank and make three or so from the same blank.)
As for spinning, much depends on the surface - very smooth glassy surface is best. Also, a sharp point decreases friction. The point will last longer if the top is made from hard, dense wood. VERY important is balance - figured wood can have areas of dense and light wood and can cause a wobbly top so bland, boring wood may spin better. Dogwood and hard maple work great, as does ebony and other exotics. Beyond that, I was surprised by the variety of shapes that spun well. One of my best was contrary to expectations - it was made of light weight e.r.cedar, shaped heavy in the center and thin at the rim, but relatively wide for it's height.
Hey, when you meet for the spinoff, challenge the others to a contest spinning them upside down. If no one else is prepared, you may win that one easily. A good inverted spinner has just one additional design requirement: a sharp point on the top of the handle! The length of the handle doesn't seem to matter. (For anyone who hasn't tried it: To spin upside down, hold and twist the top exactly as you would normally, except twist your wrist first so the point is up and the handle is down. Spin as hard as you can and when released, move your hand quickly out of the way and let the top drop to the table.)
