Bubble Wrap problem. Help.
Jim Rutten
>Hi everyone,
I made a bowl for a Christmas present. The wood was sugar maple. I finished it with Watco penetrating danish oil. It had at least 12 hours of cure time and seemed completely dry. We wrapped it in bubble wrap and put it in a box. It sat under our tree for a couple of days and then was transported to its destination (no extremes of tempurature). When the receipient opened it it had, for lack of a better word, spots of glossy places where the bubble wrap touched the finish. I used a paper towel to some effect on trying to get the spots out but it didn't work completely. First of all, what happened? I would think bubble wrap would be a very safe medium to wrap things in. Second, is there anything I can do to fix it? Would another coat of danish oil level it out? Buff it on the Bealle? I would rather not go the buffing route unless I have to since this person like the satin finish of the danish oil. I will sign on again tonight and tomorrow to see if anyone has any ideas. Thanks.
Re: Bubble Wrap problem. Help.
Ed Moore
>Jim,
I was not aware that bubble-wrap and Watco oil had problems, but it is commonly known that bubble-wrap and lacquer don't work well together. As a result I always wrap a turned object in some large tissue paper before using bubble-wrap to protect it when shipping it.
You describe letting the Watco dry for 12 hours. I would want at least three DAYS before I would regard it as dry, and maybe not then. I would try wet-sanding the bowl using the Watco oil as the lubricant. Use 400 grit wet-or-dry or finer. If that doesn't work, try 240 grit and then 400.
Good luck! And Merry Christmas!
Ed
tombuchner
>Hi Jim,
Don't be afraid of buffing. After buffing just hit it with steel wool and it will return the satin finish.
I buff all the time and then cut the shine back with a very fine sandpaper or steel wool.
Good luck!
Bill Stehman
>Jim,
Ed is correct, I learned the hard way to always wrap turnings in tissue paper then the packing material no matter what finish.
Brian Hahn in SW Wisconsin
>First, as Ed said, the Danish oil wasn't completely dry. The oil wicked back out of the wood were the bubble wrap plastic touched the surface, creating the shiny areas. I wait at least a week, preferably a month before I consider Danish oil dry.
I'd put on another coat of Danish oil and rub it in with a mildly abrasive (gray) pad, or very fine sandpaper, or even a piece of coarse cloth like burlap or denim. The new oil will soften the shiny spots and the rubbing action will remove them.
Yep. And use WHITE tissue paper!
Carole Valentine
Re: Bleed-back
Ron McKinley
>Brian is right. Bleed-back of the oil caused the shiny spots. I haven't encountered that with a close-grain wood but red oak and walnut is notorious for that on a humid day.......Ron
Dick Hines
Re: Bleed-back
Dick Hines
>I use Watco for finish and bubble wrap to pack all my turnings. I have never had any trouble with bubble wrap. I do let my pieces dry for a long time before I buff them though. Depending on how fast I can 12-15 pieces. Usely is is 3-4 weeks.
don lewonczyk
>On flat work that got shiny spots because the cure time wasn't long enough when I packed them for a show and had nothing more then a brown grocery bag to rub the spots out it seemed to work very well. It was a tip from a woodturner, didn't hurt the finish any either. I guess the wood products in the paper bag acted as a abrasive and a burnisher also. Worked well enough to be able to sell the piece.
DonL
Another amazing revelation!
Bill Howatt
>I've been reading various woodworking and turning forums for years and here is another case of "never heard of that problem before"!
Anyway, now I have heard it and will take some extra care when wrapping just in case I have a problem like that. I wonder how long it will be before somebody posts "tissue paper sticks to un-cured turnings and leaves white patches of paper"?
My feeling is that 12 hrs isn't long enough for a good dry let alone to even think about curing.
Bill
Re: Bubble Wrap and Shellac
Mike Jones, Redding, CA
>It was very embarrassing when a gallery called and told me that a shipment of work that I had sent had "finish issues" upon arrival. A grouping of large tall goblets all had markings from bubble wrap, and, they had been carefully wrapped in tissue first. I think that the final-final coat of 'french polish' shellac had been applied at least three weeks prior to wrapping and shipping.
Lyle Jamieson
Re: Another amazing revelation!
Lyle Jamieson
>I have been using Watco for decades, I love it. But it is a wiping varnish mixture of oils and will cure slowly. I like to wait at least a week before I even put a second coat on. The second coat will soften the first if the first coat has not had a chance to cure deep down in the wood fibers. The can says ready to use in 8-10 hours (thats a stretch!!) and recoat in 72 hours but that will lead to problems. In my experience the key is, letting the first coat cure, and then you can proceed with buffing or second,
third, or fourth coats, 24 hours apart.
Regards
Lyle
cold shop, evil plastics
JohnKJordan in East TN
>When drying oil consider the temperature and humidity. My cold garage shop is a poor place for drying finishes. In the winter I sometimes set oil-finished pieces near, but not too close to, my woodburning stove. In the damp summer, I set things inside in the air conditioning.
I read once to make sure the first coat of oil is completely dry before adding a second. Perhaps the solvents in undried oil which initially soaked deeply into the wood will soften later coats over time.
And consider the bubble wrap. Most bubble wrap appears to be made of polyethylene but I found one composed of "Polyethylene and other proprietary resins". It didn't say what resins. And many plastics outgas to some extent. Maybe it's safer to keep plastics away from fine finishes.
I also found a type of bubble wrap touted as biodegradable. This has a "shelf life of approximately one year and breaks down naturally once exposed to the environmental factors such as oxygen, light and mechanical stress". It contains an additive which "breaks down the carbon-hydrogen bonds in plastic" and "acts as a nutrient for microbes" converting the plastic to water, CO2 and "trace biomass." It's easy to imagine that some of this in contact may affect a finish.
