Please Help!
Please Help!
Please Help!
Bruce Evans
>Happy Holidays to you all, and please help me if you can. I have not turned for years and just recently got the urge to break out the chisels and do something that was not a home repair. I came across to very handsome chisels that I purchased made by the Hirsch company and would like to get their actual names and usages. (Sorry, no pictures, my son has camera for the holiday!) The first, #1649 26, is flat and wide until the end where it narrows from one side and then swells into a ball. I'm guessing some sort of bowl scraper? The second, #1639 20, is flat, almost rectangular, widens at the end which is cut on a diagonal both laterally as well as top to bottom.
Another scraper? I feel like an idiot for not even remembering what these are for but I recall being interested in bowl turning years back in the time I call "BH" - "Before Home-ownership"!
Thanks in advance for your help and best wishes to you and yours.
Re: Please Help!
Re: Please Help!
Barbara Gill, Remlik VA
>I may be wrong, but aren't Hirsch tools for carving (i.e. bench chisels)?
Re: Please Help!
Re: Please Help!
>Unless they are carving tools like Barbara suggested the first sounds like a scraper for hollowing under the lip of a hollow vessel or a bowl with the lip curved well over.
The other sort of sounds like a skew. Many people use it like a scraper but it's actually for cutting on spindles. It is best used to make long straight tapers and gentle curves. When you get good with it you can make beads, and balls.
Re: Please Help!
Re: Please Help!
>I don't think that any Hirsch turning tools are common in the U.S.
Re: Please Help!
Re: Please Help!
bowlman
>Hirsch chisels used to be quite common and sometimes went by the "Two Cherries" name. Just some more trivia in my dusty, musty old brain ...
Re: Please Help!
Re: Please Help!
Bruce Evans
>Thank you to all who have responded...
No, these are not bench chisels. I am very familiar with regular turning chisels, have a set of short handled Craftsman, and these two match none of them.
When I was working for ShopSmith I picked these up on closeout (about 25 years ago) and then they got safely tucked away - along with my memory of what they were for!
The skew type is different from a normal skew in that it is nearly twice as thick and has only one bevel face in the end of the chisel.
The end is cut on a diagonal, left to right, and beveled back towards the handle from top to bottom, through the whole thickness of the blade.
A regular skew is cut on the diagonal but then is beveled on both top and bottom to a sharp center edge.
These both have the Hirsch Werkzeuge sticker and numbers stamped in their handles. Hope this helps someone to help me!
Re: Please Help!
Re: Please Help!
Don Evans
>The one with round end is just another scraper, still can get them.
The second one sounds like a bedan to me.
Why don't you go to www.craftusa.com or www.packardwoodworks.com
and look over the tools and find them that way.
Probably more accurate than trying to describe them as it depends on how the tool would be used, so left right may well be top bottom etc.
What part of the world are you in, maybe you could stop over?
Don
