drilling holes in spindles
Carol - now in NC Nebraska
>Need some advise, O Wise Ones.
I was inspired by Jen's screw drivers and needed one last Christmas gift. How to drill the hole is the quandary.
I downloaded and printed out the helpful "Turning Tool Handles" by Ron McKinley on Doug Thompson's site. And I rough turned a cherry cylinder. The shaft of the driver is 1/4" so tomorrow when I get the mail I will stop and get a brass coupling nut for the ferrule (while the garage is warming up!).
I am OK with Ron's instructions until how I am to hold the spindle to drill the hole. Maybe I am missing some sort of tooling here. My chucks don't reach very deep and I don't have a spindle steady. I do have the Jacobs chuck to fit the tailstock. And I do have a bench top drill press, but...not enough depth reach.
The Talon reaches 1/2". Is that enough? And do I want to wrap my hand around a spindle turning at 500 RPM and run the drill bit in cranking the handle on the tailstock? Have to go about 1-1/2" given the handle I am cutting off of the bargain driver I bought.
Do I need spigot jaws, not that I can get any soon enough? How do I hold the spindle on the lathe to drill the hole to keep it centered, bearing mind that I would like to complete this little project tomorrow?
Thanks for helping.
Re: drilling holes in spindles
tek-Brunswick, Ohio
>If the spindle diameter is too small for your jaws on the Talon you can take the jaws off and clamp a small diameter tenon in the slides the jaws screw on. Just make sure you don't open the slides to far so they fall out. I would use the live center on the tail stock to align it,clamp the spindle in the chuck, then back off the tail stock and replace the live center with the drill chuck. After you drill the hole use a cone on the live center and snug that up into the hole. Now when you finish turn the outside, it is centered on the drilled hole.
Jake Niedling
>Carol - I am sure there are many ways to do this. The way TEK recommended will work just fine. Another option is to put a tenon on the opposite end of the hole end while between centers. Take it off the lathe and then place a scrap piece that you have left over from another project that all ready has a tenon to fit your jaws on the chuck. Face off the scrap piece and turn a hole to fit the tennon on the spindle. Now super glue the spindle into the scrap wood still on your chuck. Use your live center in your tail stock to hold it on center while the glue sets up. Now pull away your live center and replace it with the Jacobs chuck. Drill your hole to the desired depth. Do not hold on to the spinning wood. Remove the drill and jacobs chuck. If you have a cone that fits on your live center, then use it to support the free end of the spindle. If you don't, then you will need to make one out of wood. All it needs to be is a wood tapered cone with the live center hole still in the end. Then just jamb this wood cone between the live center and the free end with the hole. Now you are fully supported and ready to finish turning the handle. As for assembly, I would probably use epoxy glue. If unavailable use super glue.
My thoughts.
Jake
Ron McKinley
>Carol, I turned a tenon on both ends and used stepped jaws on the Talon chuck but Tek and Jake have given you other alternatives.
If you have access to Wood Magazine, Nov 07, issue 180, they have step-by-step instructions for making the screwdriver handles. They drill from the headstock end with the drive center in the tailstock so you don't have the spindle spinning while you're drilling plus they drill when the stock is still square which makes it easier to hold. This requires a cone center earlier in the process and they show you how to turn a cone center from a piece of scrap wood. Basically, turn a piece about the size of your live center on the lathe using your four-jaw chuck and then drill a hole in the tailstock end to fit the diameter of the live center. Then shape the headstock end at about a 45 degree angle and part off. Then simply mount your wooden cone center over your live center and you can shape the rest of the handle.
I recently demonstrated to a group how to make this cone center and mis-judged the depth of the hole I drilled with the Forstner bit and made a real neat funnel! The second time I got it right!
Good luck and hope you get your gift finished by tomorrow....Ron
Mike Brazeau
>Carol - when making handles here is the way I do it with standard #2 jaws on Talon. Round the blank bewteen centers so that you have a center mark on each end and cut a tennon for the end which will be then chucked in the Talon jaws. Rough shape it with one end chucked and size the end for ferrule. You can slide the tailstock back and easily check for fit. Finish the rest of the handle including friction polish or whatever you are using. Mount a jacobs chuck and drill in the tailstock, reduce lathe speed and drill to appropriate depth. Remove jacobs chuck and remount live center in tailstock. Flip the handle around and use the small diameter inside the jaws to grip the area sized for the ferrule and the butt end will be centered at the tailstock. Finish the cutting the end at the tailstock and sand and apply finish. Remove, glue ferrule on with some thick CA or 5 minute epoxy and insert tool and glue if necessary.
>Thanks, Ron. I have already rounded it but I will try it anyway. Putting the drive center in the tailstock makes more sense to me when using the drill bit than the other way around. I am not sure how I got the idea of putting the Jacobs chuck in the tailstock. And, joy of joys, I already have a cone center with my live center.
As soon as my message for tonight's Christmas Eve services is completed and the garage warms up, I'll give it a go. Picture to follow upon successful completion. (Notice the qualifier? :) ).
>Thanks, Mike. Yet another way to do it. Ron (below) suggested holding the stock and putting the drill bit in the drive end of the lathe. That seems to make more sense to me, but I will study your method a little more, as well. I appreciate how you presented each step in sequence for this newbie turner. I love step by step directions!
Steven Antonucci
Easy way with very little tooling requirements
steve antonucci
>1.) round between centers
2.) chuck one round end, since you have a chuck (could use the spur also)
3.) align drill point on other center
4.) drill to depth
with the lathe running slowly (400rpm) you can easily use your hand with or without a glove as a steady rest (your choice).
5.) cone center in drilled hole and turn to finish
steven
Re: Easy way with very little tooling requirements
>This brings up another errant thought. Is there such a thing as a 1 x 8 threaded M2 adapter thingie to hold a chuck in the tailstock? If there is, what is it called? I can envision occasional use for one of these.
The problem with Googling is that I have to have an idea of what to enter into the search box. LOL
Barry Elder
>Carol, there is such a "thingy" but I'm not sure what you would call it either. Probably one of the suppliers would have one, Woodcraft, Craft Supply, etc. I bought mine as one piece a long time ago. Have a Happy Holidays, be Safe, and keep turning and learning!
Re: You don't need a chuck.
Russ Fairfield
>You drill a hole in a spindle the old-fashioned way that was used for a couple centuried before the advent of chucks a few years ago.
All you need is a center in the tailstock and a drill it the spindle. Support the spindle between them, start the lathe to spin the drill, and grasp the spindle in your left hand to prevent it from spinning while you crank the spindle onto the drill with the tailstock. A spade or brad-point drill with a long center point will make it easier to start the drill into the wood.
Tailstock Thingy
gtwilkins
>Carol,
Yes there is such a thingy, called a tailstock chuck adapter they have them at:
http://www.bestwoodtools.com/
Go to Woodturning Tools and Acc.
Hope this helps, Trevor
Re: Tailstock Thingy
Gordon Seto
>CAUTION,
the thingy is made out of aluminum and not designed for use when the lathe is running. It is an alignment tool for reverse vacuum chucking.
Gordon
Gordon Seto
>What Russ said worked.
Gordon
>That's the method that I use. If your nervous about this put a clamp or a set of channel lock pliers on the wood for leverage. I've only had a few get away from me over the years but it hasn't been any big deal.
