Respirators
Julie
>why type of respirator do you folks use?
I know there is a thread about this issue, I cant seem to find it.
Respirators
Julie
Re: Respirators
Stuart Johnson
>I use a 3M half face respirator. It fits under my face shield and my glasses don't fog when using it. You can get different filters depending on what you are doing.
Re: Respirators
Julie
>what cartridges are you folks using with your respirator?
Re: Respirators
>I use a North 7700 because it fits my face and it fits under my mask and does not fog my glasses. I use combination filters that are physical filters and charcoal filters. Might be better to use separate ones and they are available, but I am too lazy to switch back and forth. I really like the charcoal. Can't even smell the lacquer and if I wear the mask the lacquer does not bother my nose. Great. Barbara Gill recomended this mask because it fit her face.
Sniff
Gil Jones
>For organic vapors (such as lacquer), I use a 1/2 face, Cabot AO 5 Star, dual element respirator (with the appropriate screw-in filter cartridge and pre-filter).
For wood and grinding dust, I use the Trend AirShield.
Gil
North 7700 Half Face Mask.
Barbara Gill, Remlik VA
>Very similar to Stuart's.
Re: Respirators
Stuart Johnson
>I have one set for vapors but the ones I normally use are the ones for particulates.
Re: Respirators
JohnKJordan in East TN
>I use three devices. One is a powered helmet (Trend Airshield) which I use primarily in the summer when my garage shop is hot because it helps keep me cool.
For most sanding I prefer an industrial respirator. I have both a full face shield respirator and a couple of the respirators without the mask, similar to what is shown in the attached photo. I use pink 3M dust filters at the lathe. You can buy this equipment at any industrial safety supply house and some is sold at Home Depot, etc.
A good respirator is FAR better than the cheap paper filters: it does not inhibit air flow, doesn't cause moisture buildup, won't fog glasses, won't let dust in around the edges, and is very comfortable even when worn for extended periods (I hate the rubber bands on the paper filters). I appreciated the good seal while sanding cocobolo just a few minutes ago - if I breath a little cocobolo dust my lungs suffer.
I use the full face shield respirator primarily when working with ag chemicals or spraying finishes (using a filter made for volitiles). Might also be useful at a Chili cookoff competition.
Re: Respirators
Martin Harris
>I was about to buy Trend when the last thread was posted, but was persuaded to order a North 7700 half-face mask with North 7580-P100 particulate filters. It works extremely well even though I have a full beard. I do't do shellacing, etc. so can only speak to dust.
I'm even thinking of using when house cleaning, as now I sneeze more doing that than turning :-)
I ordered it from library-dust.com; $36 including 2nd day air.
Re: Respirators
>>I'm even thinking of using when house cleaning...
That should help. (If you're allergic to house dust as I am, you might also try a vacuum with a HEPA filter, such as a Nilfisk)
I also use my respirator when mowing kicks up a lot of dust and when crawling under the house where there may be mold.
Re: Respirators
Julie
>Thanks a lot for all the helpful responses folks,
now I hope santa leaves me some cash.
Happy Holidays
Re: Respirators
Brian Simmons, Heflin, AL
>I have an old obsolete 3m airstream. I had to make adapters so I could run the belt pack using screw in filters. I got tired of the weight of the backpack and built me a 20x20 filter box. I use 3 furnace filters, coarse (blue fiber type), fine (paper type) and smoke filter. To supply the air I used a combustion blower out of an old gas furnace, it is on a remote control so that I can turn it on or off at the lathe. The supply pipe is 2 1-1/4 25' (total 50')sump pump hoses. When I spray something nasty like paint a car, I can move the filter box outside or in my air conditioned metal shop next door and pump the fresh air from there into the larger wood shop. I find that a papr (powered air purifying respirator) is much more comfortable than a standard resprirator. It doesn't fog and is also cooler as the air is constantly flowing into the helmet. I don't always use it but I know that spalted woods, black walnut and poplar will clog up my sinuses. I always use it on wood that may fly apart as the lexan shield can (experience talking) take a real beating.
Re: Respirators
George Van
>John, is the top one comfortable to wear for long periods in the shop? I have the Airstream but at times would like something less confining and lighter when the dust is not heavy or for running flatwork machines.
