Center nub removeal
Center nub removeal
Center nub removeal
>Here is how I get rid of the center nub using the Hunter #4 tool. I start with the handle well to the right to avoid any chance of a catch. Push the tool against the bottom and the move the handle to the right until it starts to cut. Now your on the bevel. If you keep the cutter fairly steep, 45 to 75 degrees it will simply stop cutting at the center. Sometimes on big nubs you may have to "whittle" away at the top before making a pass all the way from the bottom of the box to center.
I apologize for the focus. My son was using the camera and our eyes are different. Apparently I didn't get the diopter set exactly right. I'll go back and check that.
Re: Center nub removeal
eliot d
>Looks perfect. I don't have a Hunter tool, and for others who don't, here's a different way: If your lathe has a reverse, turn in reverse and simply use a swan neck tool approaching from the right side of the nub. ( I actually think I'm the only one who does it this way.)
Jeepers, John, the pic is good enough.
Eddie Pacheco; San Jose, Ca.
>It's a "normal" focus for most of us in this age group! Thanks for posting this.
Lynn Edwards
>I don't have a hunter tool(the hint went out for Christmas). Hopefully I will be able to find all the information on the use of this tool if I get one:)) Thanks for posting.
Barry Turner
>I should have a Hunter tool in Santa's bag this year. I'm excited about getting to try it out.
I tried this last Saturday...it works
keith zimmerman, Normal IL
>The presentation of the tool like John illustrates when removing the nub is really simple and extremely logical. I was not able to even get the tool to cut when presented any other way. I also found it almost impossible to cut deeper that the bottom. I think because when presented this way, you are riding that bevel which creates a very smooth cut and simply glides across the wood.
keithz
