Silicone problem
Silicone problem
Silicone problem
Bill Crommett
>Because I wanted to make a couple of wine goblets for my Daughter, I ordered some goblet tops from Craft Supplies. But because I thought best to practice on something cheap first, so I went to the local thrift store and bought some $0.25 goblets and used them for practice. No problem with the first 6 practice goblets using the silicone as advised here. Of course Mr. Murphy showed up at the last minute and on the last GOOD goblet a big chunk fell out somewhere. Now I need help in getting the old broken glass out of the beautiful Dogwood stem. What can I use for solvent that won't destroy the finish on the wood or discolor it beyond repair ?
Re: Silicone problem
Dennis Yoder
>Bill, I believe that silicone uses vinegar as a solvent. Don't know what it would do to your finish. Have a few tops if it would help at this late a date. Dennis Y
Bill Crommett
>Thank you Dennis, but it is the wood that I am trying to salvage. I still have enough tops.
Brian Hahn in SW Wisconsin
>Bill, the lack of responses is very telling. I don't know of any common solvent that will touch silicone after it has cured. Apparently no one else does either.
Mark Wollschlager
>Why don't you try a working thin feeler gauge folded around the stem to loosen the grip of the silicone.
A small drop of glass adhesive on the top of the stem might give you something to stick to to pull it out once released.
Just a thought. Good luck.
Mark.
John Veerkamp
>Bill,
The only way I know to remove silicon once it is cured is with a razor blade,
John
Bill Crommett
>I will persist and report back.
Wayne Kuhn
>Try PVC Cleaner-The clear stuff not the purple. I had some luck with that many years ago before I knew silicone is not paintable.
