OT: What happened ...
RevDoug
>to the read messages changing color. They are all remaining blue for me right now. Is there a setting that I need to adjust somewhere?
Turn 'em round,
RevDoug
Turn 'em round,
Re: OT: What happened ...
Bill Blasic
>Doug,
When I click a thread off the main index, read it and go back that thread has changed color. I'm set up for guestbook so when I click a subject off the main index all responces are below the main one I clicked, when I have read all and go back only the first one I opened changes color. So I guess I'm saying that only the threads that you click on from the index actually change color. If there is a way to change that I haven't found it. Hope this helps.
RevDoug
>Bill, they are all blue whether I've read them or not. They should be changing to green once their read.
Turn 'em round,
Brian Hahn in SW Wisconsin
>Having the links change color is usually a browser setting. At least that is the only place I've seen it. That's where I'd start looking.
Possible Solution
David Yoho
>If your read messages still don't change color after leaving WC and closing out your Web browser and then coming back again, it probably has to do with your WC cookie being corrupted. The easy way to fix this or just check if that's the culprit is to delete it/them (there can be several).
If you're not sure where this cookie is located you could try doing a search in Windows Explorer for - woodcentral.* The star symbol is a wildcard character and tells the computer to locate any file with woodcentral in it with ANY file extension after it. The cookie is a simple TXT (text) file.
Depending on how your computer is set up, the most likely place to find your WC cookie on a Win XP machine would be this path -
C:\Documents and Settings\Administrator\Cookies\administrator@woodcentral[1].txt
Once you locate it, delete it. The next time you log onto WC, you'll have to supply your name and password again before posting messages in each forum you visit but it will remember you after that. See if this don't solve your problem.
David
RevDoug
>Don't know what happened, but over the last few days the read posts are now turning green as they did before. Thanks for all the help.
Turn 'em round,
