Way off topic
Way off topic
Way off topic
Steven Smith
>I have a Sears (first problem) built-in microwave. It smells like a rat or something died in it so I took it apart and I think that the odor is coming from the mother board behind the control pannel. Is that possible? The whole thing stinks so that I can not tell which part is stinking. Is it repairable by a novice like me or do I have to call the repair service? Sorry to take up space here but I dont know anyone to ask.
Re: Way off topic
Re: Way off topic
Lan Brady
>Steven,
I am a piddler, not an electician so my response is worth exactly that. I made several repairs to our microwave. The only thing I would not touch is the ray tube. I was concerned that it has a capacitor that was still holding a charge. Other than that it is pretty simple.
If it requires a service call, you may want to consider replacing the entire unit. You will have nearly 70% cost of a new one in the repair.
Sears does have a good parts replacement store for us. As long as your microwave is not more than 10 years old, they have the part.
Good luck and Merry Christmas, Lan
Re: Way off topic
Re: Way off topic
Bill Howatt
>If you aren't an electronics person and the fault is not a bad safety switch or blown fuse it is unlikely you are going to fix it yourself. Before you proceed look at the cost of a replacement unit. Also, look at one that has the features you actually use - probably will drop the price even lower. You can get basic units for under $50 now.
Bill
Re: Way off topic
Re: Way off topic
>You did not say how old it was or if it were built in. Sears had a major recall on them a few years ago and some of them are still out there. There was an X in the serial number. Call Sears and see if you have one of them. If it is, they will fix it. (It was a fire hazard, something about crud in a guide body).
Re: Way off topic
Re: Way off topic
John McAlevey
>General Electric makes Sears microwaves and had a major recall of microwaves last month.Check out the G.E. or Sears website.
Re: Way off topic
Steven Antonucci
Not trying to be a wise guy...
steve antonucci
>Many years ago, I was working as an IT contractor and deployed to a client who made home electronics. I was going from service center to service center installing PC's, where they employed between 10-25 people to repair anything and everything the vendor made.
I was absolutely amazed at the number of people who would spend $50 to repair a $25 phone... Obviously, enough people to support having that many FTE's on the payroll, and 8 service centers on the West Coast.
If the item isn't covered by the recall that other folks have mentioned, do yourself a favor and get a new one.
Steven
Steven
Re: Way off topic
Forget about fixing it yourself
Russ Fairfield
>There is nothing inside of a microwave oven that the novice home handy(?)man should be fixing. In fact, there are parts in there that will store up enough electrical charge to knock you on your butt if they aren't properly dischatged.
Take everyone's advice. Take it to a repair shop if it is under warantee. Throw it away if it isn't.
Re: Way off topic
Re: Way off topic
>Steven You can probably remove the outside covers fairly easily. If it smells like a rat it is probably some electrical insulation being burned. It that's the case there might be a more serious problem. The one downside to working on micowaves is to be sure you put everything back exactly like it was. you don't want any microwave leaks.
My suggestion would be to put a box of Baking soda in there and let it sit for several days. With luck that will soak up the smell. It worked for the microwave that I accidentally burned a piece of wood in.
Re: Way off topic
Re: Way off topic
Steven Smith
>Thanks for your advice everyone. I would throw it away but its a built-in that I designed the cabinet around. Guess I will call the repair service. Thanks again.
