Turning Legs
Turning Legs
Turning Legs
Wayne
>I have read a few articles about turning legs I believe it said to turn air dried wood, rather than kill dried wood. Is this correct if so what is the reason?
Re: Turning Legs
Re: Turning Legs
>I've made a lot of legs out of Kiln dried wood and few out of air dryed . I don't think there is a difference other that some woods will have better color with air dryed. If the kiln drying isn't done properly you could have honeycomb problems but that's a different ball game and I've never run into it with the people I use for my wood.
I'll be interested to see if others know of a reason to do one over the other.
Re: Turning Legs
Keith Tompkins
Re: Turning Legs
Keith Tompkins
>HI Wayne, traditionally, chairmakers used semi-dry wood for chair legs, rails, and stretchers. The tenons, after turning, were inserted in hot sand, which helped dry them completely. The round mortises, or sockets, were drilled in the partially dried parts, and the dry tenons inserted. The dry tenons would absorb moisture from the sockets and swell up, locking themselves in as the socket shrank around them. Hope this helps.
Re: Turning Legs
Re: Turning Legs
>What Keith said. I've turned legs out of kiln dried, air dried and also green lumber.
Kiln dried - dimensionally stable. You generally need to keep sharpening your tools as they will dull a bit quicker. You can sometimes have a problem finding thick enough blanks for some turnings. As an example, 8/4 lumber is often only 1 3/4 to 1 7/8" thick. So you often have to buy 10/4 (and sometimes 12/4) for some turnings. Usually stains well.
Air dried - reasonably dimensionally stable. Turns easier than kiln dried. You usually can get reasonably thick blanks. Sometimes the lumber will go slightly out of round after (or even during) turning if it isn't dry enough. Generally turns well and stains well. Sometimes you have to treat it as green lumber before gluing i.e. dry them with the mortise areas wrapped in aluminum foil.
Green lumber - not dimensionally stable. Turns easiest of all Your blanks are what you get out of the tree so size is not a problem. The turnings will go out of round. I usually rough them out 1/8 to 1/4" greater than my intended size (sometimes more). I then dry them in a hot box (120-130 F for several days) with the mortise areas wrapped in aluminum foil (tenons and leg ends are fully exposed). I then put them back on the lathe and finish turning them. The joints are usually a lot tighter and don't need much glue.
As far as differences in finish and staining? They all are fairly dry by the time you stain and finish them, so I haven't seen much difference.
My $0.02.
Re: Turning Legs
Re: International shipping
Gary Evans Tallassee, TN
>Hey Keith,
Some weeks back you posted about the outrageous cost of shipping your guage overseas. Someone else posted that he was well familiar with the in's and out's of international shipping.
I have searched on WoodCentral for the thread, but so far haven't found it. If you remember who that was, I'd like to talk with them.
I hope that you and yours have a memorable Christmas this year.
Gary
