jet JWL-1236 problem
Nick
>The speed control on my lathe doesn't seem to be working right. Is the split pulley on the motor shaft supposed to expand and contract like the mandrel pulley?
Nick
Re: jet JWL-1236 problem
Dennis Taylor
>the pulley inside should open and close as you are turning the speed lever Up & Down....not sure what the problem is, but it could be that the pulley inside is GUNKED UP, I cleaned my old one with brake cleaner as perscribed by the manufacturer, and it would always resolve any issue I had....maybe more problem info is needed!...Dennis
Nick
>Reading other posts on this topic, I realize that you are probably right. My problem is that the pulley (sheave) is really stuck. I've tried prying the two halves apart but no luck. Yesterday, I put some penetrating oil on the shaft; maybe today there will be some movement. I might try heating the pulley and tapping on it. Any other ideas?
Old Cosmoline
Dominic Greco in Richboro PA
>Nick,
I had the same lathe and had the same problem. Part of the problem was the cosmoline (as a rust preventative) they applied before shipping the unit. Liberal application (read that as "really dousing it with") mineral spirits worked wonders. I would suggest using the same.
After you get it freed, I would apply some dry lube (used on bicycle chains and gears). Dow Silicone Dry Film Lubricant works well too (that's what I used).
Good luck,
Dominic
Re: Old Cosmoline
Ron in Drums PA
>The pulley on the motor side is easy to take apart and put back together.
There is a ring on the shaft that you spread open, then you can slide the parts out. Clean and lube the shaft and mating surfaces, replace the parts and you are ready to go.
