>I've been having fits with the inside bottoms of my boxes. I'd like for them to be fairly flat. I've been using a flat scraper - but I get the occasional "dig" - probably because they are fairly deep.
>I use several methods. A light touch with a round nose scraper works. If you have a nub in the bottom start below the nub and gently move the scraper straight up taking off a little bit at a time.
I do the same thing with a bowl gouge or spindle scraper if I use those to hollow. You can remove the nub by very carefully putting the nose of the spindle gouge right on the center of the nut and pushing. Then move the tool across the bottom to flatten it.
I do the same thing with the Hunter tool but I've been experimenting with a new technique. The hunter tool has a slight bevel to the outside. I will place the tool to the left of the nub with the sharp side toward the middle. I have the handle to the left so the bevel of the tool rubs and the cutting edge isn't cutting. Then I move the handle to the right until I pick up the cut and move tool to the right cutting off the nub. The tool is held so the cutting edge is from 12 to 6. If the tool is held this way is stops cutting when you get to the center. This is a little tricky but I think it's worth persuing.
>The "Berger" tool is my absolute favorite for boxes, vases, and anything with flat bottoms and/or straight sides. It can cut very agressively if you want, or, take very light cuts to finish. Almost no sanding required. I liked it so much that I have a second one mounted in a large diameter shaft that produces those excellent cuts well out over the tool rest.
>Grind a very slight radius on your square nose scraper. Catches occur when you have the full sharpened edge on the wood at once. Also, as others have said, raise the tool rest a bit so that the handle is pointing up. To get that final tiny nub in the center, place the tool edge just below it and lower the handle. Nub disappears.
>I do just as Wally suggested with one variation. I radius the edge of my straight scraper going from the left to the right so that for all practical purposes if you were to measure the angle from the left side it would measure 88 or 89 degrees. I also relieve the left edge just a bit so that it is tapered along its length so that there is not as much to contact with the side of the box. And lastly I grind a very fine radius on the left corner just to make it less sharp. It is easier to sand if the corner is not dead square. It also helps to remove the burr when you sharpen with a diamond hone. I like a sharp edge but not the burr.
When you are using the tool you should stroke the bottom very gently and with the radius on the end you should not have the whole edge come in contact at once with the bottom. When that entire edge comes in contact with the bottom the likelihood of a catch/dig in really goes up.
And lastly, a box rest, a flat tool rest that extends into the box will shorten the amount of extension over the rest that you might have with the tool making it easier to control.
>Using the 3/16 Hunter tool to remove the nub,(that I usually put on there with the Hunter tool :)) the way you described has worked for me, too. High speed, light touch. With the tool oriented like that, so close to the center, it doesn't even attempt to catch... but if you did that away from center it'd be inviting one.
I also remove the nub by using my 1/2" bullnose scraper, Handle almost level, cutting edge level and center height, move in just to the left of the nub till touching the wood, then swing the handle left, which moves the cutting edge to the right, peeling off the nub. Hi-speed, light touch. Works well, also.
>I also use a flat scraper, very slightly radiused across the end, and with a radius on both the left and right corners. If I have trouble flattening the tiny hill in the middle of the bottom of a deep hole, I usually turn the lathe off and use the same scraper by hand, sort of like using a cabinet scraper.
>In spite of my bitter complaints about trying to learn to use the Hunter Tool the other day, it really does excel at this. I have the No. 1 which is a 3/16" cutter mounted on a piece of 3/16" The angle is all preset for you. It will fit on a Jamerson captive rig or a Sorby Hollow Master in place of the little HSS tooth. Point it straight ahead and it cuts beautifully between the 11 and 12 o'clock.
