Polyanna Box with multi-center top
Craig Daymon
>Here is a box I made for the Bucks Woodturners annual polyanna. The insert in the top is multi-center created on a multi-center faceplate I made. I'll post that in a separate message. This first shot shows the top and a reasonably full profile of the box.
Re: Polyanna Box with multi-center top
Another shot, better top view
Craig Daymon
The inside - dimensions and material info
Craig Daymon
>Curly maple insert in the top (for obvious reasons).
The box is cherry, about 3.5" x 4" in size. The insert is walnut ebonized with sharpie marker. This caused problems with the Shellawax finish, but luckily cleaned up pretty well. The insert (both inside and outside have a single coat of poly before any shellawax.
-Craig
P.S. I'm not sure that second pic really is a better view of the top. Maybe just a different view?
Bob Way, Canton, MI
>Craig, you've certainly put some thought into your faceplate, and took real care in your setups to get your top to come out as nicely as it did. I would imagine the turning was the easy part. I like the ornamental look, and look forward to seeing where you go with this.
Bob Way
Canton, MI.
Really nice, Craig
Jim K in Trappe, PA
>I like all of the off center ornamentation. Beautiful!
Jim
Mike Stafford
Really nice work!
Mike Stafford
Thanks for the kind words...and what I didn't do.
Craig Daymon
>It actually isn't quite all that I had hoped. I had hoped to figure out a way to run 3 finials angled up from the circle centers to connect to the base of a central finial. I'm still working out the necessary tricks, so hopefully it will happen on a future box.
-Craig
Duane C.Leach
>Nice work Craig. I have done some of this typ lid and i find them to be a lot of fun. Here is an idea you mite want to consider. Start in thre center inside and cut rings or grooves. The grooves shoulb be deep enogh to break through to the groove bottom on top. A typ of latice work.
Just my 02. worth.
Duane
Ain't turning fun
Fantastic Box
Jennifer@Indy.USA
>Craig this is really neat! It's wonderful. Reminds me of Spyrograph when I was a kid. I was always amazed at that toy. I love your jig in the post above too. Very smart design. Thanks for sharing!
Jen
Well done my friend!!!!
Dominic Greco in Richboro PA
