Index plate
eaglesc
>I seem to recall an index plate for a Jet mini that sold for about $40.00.
It was aluminum with a 1x8 thread.
I also recall it was made here in the U.S.
Anyone have the link?
Index plate
eaglesc
Re: Index plate
Gary Ljostad
>http://alisam.com/page/14g9e/Woodworking_turning.html
Re: Index plate *LINK*
Brian Simmons, Heflin, AL
>on ebay, I am not associated with these folks.
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=34&catref=C6&from=R10&satitle=index*&sacat=-1%26catref%3DC6&sadis=200&fpos=36264&sabfmts=1&saprclo=&saprchi=&seller=1&sass=timq&fsop=34%26fsoo%3D1
Re: Index plate
eaglesc
>That's the one, thanks
>Eaglesc the index plate from ironfire works absolutely perfectly and is only $19. It's made from sort of tough plastic. I can't imagine tearing it up and if you drop it you won't bend or dent it. I have one for my Powermatic and love it.
http://www.ironfirellc.com/shop/
Indexing Plate Lock Q
Rick Urban
>John, I've looked at that one and was leary about the plastic, but if it's good enough for you that's good enough for me. Could you post a pic of it mounted on your 3520 with the pin/key/lock mechanism?
Re: Indexing Plate Lock Q
>Rick I'll post it tonight. I have the photo on my other computer
eaglesc
>Not that I don't believe you John but I am leaning more towards the aluminum one.
How thick is the plastic one?
Re: Indexing Plate Lock $2.99
Mike Jones, Redding, CA
>The pictures show a prototype index-plate/spindle-lock made from scrap aluminum and MDF (made on my pm3520). The $2.99 was for the slide bolt which is attached to the top of the headstock. It seemed a little crude at first, but, like many of my prototypes, I just keep using and using. I use it as a "multi-position spindle lock" only, but you can see how easy it would be to make an indexer out of it.
Merry Christmas!
Re: Indexing Plate Lock $2.99 Pic 2
>Rick Here it is. It is a slightly tapered block to match the taper on the headstock. I drill 4 holes that match the index plate holes. I did this by clamping it to the index wheel and drilling through the holes very accurately. I think I used a #37 drill but would have to go check that one.
I installed the index wheel and put index block in place using the supplied index bar and the #37 drill to align it with the index wheel. I put double stick tape on the back of the index block and stuck it to the lathe. Then remove the index wheel and drill a 1/8" hole through the block and headstock. I drill 2 holes, one at each end. then drive a 1/8" roll pin into the holes in the block and headstock.
>Eaglesc I would have to measure it but it's 1/8" or thicker. Not 1/4" I'm sure. It has a huge number of division possibilities. I don't know the material it's made of but something like Nylon or UHMW. Very tough stuff. That's why I hate to call it plastic. More like Lexan or something along that line. I can't imagine tearing this thing up.
The only improvement I plan to make is to drill and tap my chuck for a set screw that I can screw flush when not using the index plate. I'll screw it out slightly and drill a hole in the index plate so the index plate and the chuck will always be aligned. This way if I need to remove the chuck and work from the lathe for some operations I can put it back on and everything will align. I hope. It's one of those things that sounds good on paper. Hope it works.
