REAL MILK PAINT
Lacquer Turned white question?
>I have gotten into trouble. I turned a spalted sycamore HF that was wet. I sprayed the outside with Deft lacquer that may be been satin. Not sure about the satin, there was a can of it sitting around and I may have used it instead of gloss. Anyway, I thought I was sealing the exterior so that it would dry to the interior thinking this would slow it down and reduce cracking. (OK, I'm an Idiot.) The finish turned white mostly on the end grain. It appears to be in the wood. This was not a blank, it is turned to its final thickness or about an 1/8". Any suggestions?
Re: Lacquer Turned white question?
Rick Pixley
>I'd just let it dry..Then sand lightly and re shoot the piece...When I have problems with the blushing I just re shoot when dry and the new finish mixes with the old and removes the white..I never try to remove the white before shooting..Good luck,Rick
RevDoug
>Look to the menu on the left, select "Articles", go to "Russ's Corner." Under "Finishing Secrets" you'll see "Lacquer." You'll find your questions discussed under the heading "Blushing." I'm betting that this information will help you a lot.
Turn 'em round,
Re: White lacquer = Moisture
Russ Fairfield
>White lacquer is caused by moisture. Your wood wasn't dry. That white is moisture that condensed on the underside of the surface film. It happened on the end grain because that is the direction the moisture escapes from the wood. It may or may not disappear as the wood drys.
There are only 2 things that happen to a nitro-cellulose lacquer with age. It either becomes a thicker consistency as the thinner evaporates, or it turns to amber and finally a dark brown with age. Lacquer dries by evaporation of the thinner. There is no chemical reaction as with an oil or varnish finish.
Bill Hale / The Wood Spinner
>If all else fails, remove the finish with laquer thinner and when it is dry then refinish.
I seldom use laquer because I think it is water sensitive. I do 85% of all my pieces with a varnish sanding sealer or oil. Urithane also is a great finish.
Good turning and be safe.
Bill in CG, AZ.
Kewn Oakley-Sunny St. Cloud, Fla.
>Blow hot air from a hair dryer on it being careful not to heat it so the lacquer bubbles.
Allen Neighbors
>The white is from moisture in the lacquer. It gets in either while spraying, or from the surface of the green wood.
I've had that happen before with green wood; I drenched mine in lacquer thinner, wiping it off with fresh paper towels, until it seemed to be clean. Then I put on a heavy coat of Danish Oil, and wipe it dry with an old Tee Shirt. The DO will help to seal the outer shell, and (you are correct) allow it to dry from the inside.
I don't think, at 1/8 of an inch thick, that you'll have trouble with cracking, if you don't let it dry too fast. (Don't let it set in a heated or windy area)
That's just what I would do... not necessarily the only way. :)
Barry Turner
>For some reason, satin finishes always "blush" worse than gloss. Let the piece dry then just spray it again. It should be okay.
Russ Fairfield
>A satin lacquer has small particles of "something" in it to break up and scatter the reflected light from the surface. Molecules of water in the air attach themselves to those particles when conditions are right. The result is a higher accumulation of moisture in the lacquer than we would have if the particles were not there..
Don in Central Illinois
>Russ, your knowledge continues to astound me. Thanks for being around and helping.
Mark Kauder, Phenix City, AL
>As most everyone has said, it is moisture. Three possible sources: 1) The wood is relativly warm, the air stream with the lacquer in it makes it cool, and moisture condenses (microscopicly)on the surface of the wood, and is trapped and absorbed by the lacquer 2)The wood is not dry 3) Moisture in your air lines, creating problem #1 all over again.
Usually, the moisture is trapped in the lacquer just below the surface of the lacquer layer by the outside of the lacquer skinning over before the moisture can get out. This is common in hot weather. That is why they make slower thinners and retarders. With is trapped just below the surface, there are a couple of easy removal methods 1) wait - sometimes as the lacquer continues to dry, the moisture will work it's way out over night. 2) lightly spray the piece with lacquer only to soften the surface. 3) let dry over night, and lightly sand it out.
Unless you are in a hurry, time is your friend. IF you are in a hurry, or it does not come out, wash the piece down with lacquer thinner or acetone (one of the components of Lacquer thinner), and then start again.
Deft has a retarder in it, so if Deft blushes, something is REALLY wet.
In general, if you use lacquer you should not apply if it is below 60 degrees or over about 85 degrees or over 60% humidity at any temp, without additives (retarders, etc). I do vary my thinners based on the temp. Acetone for a thinner in cool weather (it evaporates faster so everything does not run and sag). I use some thinners made for hot weather when it is hot. It is not really a retarder, per se, but just a different formulation of slower evaporating solvents. I feel comfortable with cheap borg lacquer thinner in the middle of the temp range with mild humidity.
Lacquer finishing is very easy when you know a few of the rules.
I never suggest can lacquers, mostly because you are spending an arm and a leg for very little finish and lots for the mostly solvents. Plus, you have no control over all the above. Only use them in really good conditions.
Busy at work these days, but still turning....some.
Mark
