>I move the tool post and banjo around frequently when I'm turning.When I loosen it and try to move it,it tightens up. Has anyone put a spring under the washer bolt that secures the assembly to the lathe bed? Or would that bind? How about along the axis of the handle bolt(nomenclature unknown) I did notice John Lucas's spring loaded improved tail stock 'holder downer'. I will do this fix. thks,pw
>blowing it out and cleaning underneath the banjo, clean the cam every so often and spray the ways and under the banjo with a nice silicone spray. That does it for me every time and I bet it will for you as well.
On both my lathes the banjo occasionally gets gummed up from dust and gunk so I will take the entire banjo off the bed, flip it over and give it a squirt of WD-40 and scrub it up a bit with a piece of steel wool. Give it another squirt and it's good to go. A sticky banjo drives me crazy.
>I would avoid at all costs the use of silicone on the lathe or anywhere in the shop. Silicone will ruin almost all varnish and lacquer finishes by causing fisheye and orange peel effects. The product is great for many things but the use of it in a wood shop is asking for trouble. WD-40 is, as mentioned, probably the best product. Wax sprays just gum up the ways and banjo and have no long term benefit.
>I hate to rain on the parade but I think problems with the use of silicone in the shop is way overblown. I'm not saying it doesn't happen and you should use caution. I've been using products with silicone in my shop for years and never had a problem. I was particularly concerned with the silicone base caulking that I use on my mirrors. So far no problems whatsoever. I wouldn't spray the stuff in the air. I think spraying down a lathe and then wiping off all residue is good enough. I wouldn't spray it and then grab a piece of wood I planned to spray lacquer on. I just think you don't have to panic and throw out everything in the shop that has silicone in it.
Personally I use WD-40 on my Banjo. It's still out of tune and I can't play it so I'm not sure WD-40 worked.
>Paul, I should have stated that one of the main parts I clean and scrub is the rod that runs down the center of the banjo. There is a "ring" that runs the length of it and that's what gets hung up. This is what you want to make sure you get cleaned and un-gummed.
I have ranted for years about this problem on my 1236, which I no longer use. The problem, in my case, boils down to really bad quality control and crappy machining. On my 1236, the top surface of the lathe bed and the bottom surface, against which the banjo lock works to lock the position, are not at all parallel. The lower surface is "lumpy", and the thickness uneven, so it really wouldn't matter if you were to use it submerged in a huge vat of whale oil -- it will be loose in one spot, and bind in another. The bottom surface of the banjo also needed to be ground flat, as it was pretty uneven, too, so I flattened it on a sheet of 220.
In my case, the solution is to have the bottom of the ways machined flat, and parallel to the top of the bed. I got so fed up with the lathe, and the frustration of ruining perfectly good pieces when the banjo suddenly let go and sent the toolrest smashing into my work, that I moved it out of the shop, and bought a Powermatic 3520-B. In the past 2 years, I have only used the 1236 to spin a polishing pad or buff. Right now I don't have the time or money to get it fixed.
I hope your problem is not as serious as mine was -- if you ever see a post from me selling a Jet 1236, don't buy it !
>Like John I think the silicone problem is a non-problem. I've used auto wax containing silicone on my table saw for years. It lasts much longer than regular Johnson's paste wax........Ron
>Hello Brad,you seem more than 'put out' at the 'banjo bind'. I'm sure better machining,making the underside of the bed parallel to top,would certainly be the best cure.BUT isn't there some way to put in a spring stiff enough to push down on the locking collar to provide extra clearence? So what if you had to make a larger turn to tighten and loosen,it would be positive. Incidentially,I'm talking Jet mini lathe model 10.... Don't want to make this too long,but surely with all the great minds reading this, there has to be a workable inexpensive solution.pw
I always thought the difference was in the vehicle - besides the polydimethylsiloxane, silicone spray contains solvants like tricholorethane, dimethyl ether, alcohol, etc. Unlike wax or caulk, I suspect the low viscosity silicone mixture might be absorbed much easier into the pores of the wood, only to come out later and mess with the finish.
BTW, the lore among piano tuners is to keep products with silicone FAR away from any piano you want to keep in tune. The danger is supposedly in compromising the friction on the tuning pins.
>I needed a flat ledge on the inside of my sub-bed's I-beams so could clamp the lathe and extension bed without creating distortion problems. This gave me a good education in hand sharpening carbide tipped slot cutters (20' of ledge to cut).
I have a similar lathe with the same problem. It's not as bad as you make your's out to be, but one of these days I'll take the router and slot cutting bit to it.
>I'm not used to those big words you used John. Can't even pronounce them. But, I've never had a finish problem caused by silicone. All my problems I've caused myself! GRIN .......Ron
