It also contains reference to USA Federal Requirements pertaining to size. Brian Cliffords (a UK woodturner) website has some information on what NOT to use for a finish,
he also has a plan for a baby rattle but I don't think it conforms to the USA guidelines.
>I used walnut and elm on this one for my grand niece. I would make it at least an eight thick so it wont break if dropped. The finish is mostly sanding and a thin coat of lacquer buffed. I don't see a problem, chewed my way out of a varnished crib to go exploring and look how I turned out turned out. Gotta go, its raining and I have to go roll my windows down...
You certainly don't want stones or pebbles. You have to consider that kids break things, and at some point your rattle might be broken by the baby or an older sibling. Anything they find inside might be immediately considered to be a snack.
With that in mind, I put popcorn in my rattles. If a child eats it, no problem.
>I make them a lot like Mike's, but with a single piece of wood. I use popcorn for the rattles, but I would not use polyurethane as a finish. I have used beeswax and oil, pure tung oil, or Tried & True, which I think is edible out of the can (raw linseed oil and beeswax).
Mine have a larger diameter (~2") at one end, which I hollow out, and a smaller diameter(~1.25" - 1.5") at the other end. I chuck the blank at the end I intend to hollow, and make the entire shape as a solid piece, working toward the headstock for support. I leave a short "neck", about 3/8" diameter, between the solid end and handle, and the larger globe. The solid end is sanded and finished before parting though the neck, creating a short tenon which will be glued into the hollow globe. When parting off this tenon (I use a 1/16" parting tool), I leave a tiny length as a witness on the globe end.
Then I drill a hole to depth, making it very slightly smaller than the witness left in the parting process, and hollow the globe through this hole with 1/4" shaft hollowing tools -- straight, curved, and angled tip. I aim for about 1/8" thickness, so a small child is less likely to break it open when they hammer with it than a thinner globe. I usually leave the end grain a little thicker than the rest for strength.
Once hollowed out, I size the opening with rolled-up 220 cloth-backed abrasive until the tenon on the solid end fits well. Then I carefully shape the headstock end of the globe, sand and finish and part it off with a very thin and pointy spindle gouge, or a long-bevel skew. Lastly, I drop in a few corn kernels (play with the number for the sound desired), and glue the two halves back together with Titebond II. I don't use CA here, as its pretty shock sensitive, and I worry about it giving up under the pounding abuse it will get later.
A whole other concept is the captured ring spindle...
>Barry, I saw one in a turning ideas book that had captured rings instead of rocks or beans to make the rattleing sound. Check at Wood Craft Thursday night. I bet ther is a book with one like this.
>I made one and filled with dried beans. The finish was several coats of mineral oil. I made it donut shaped so there could never be any concern of choking. My niece loved it. Easy to hold and to hang on an arm.
