Question finishing
Steve ponch
>I am a new turner. I turned two ambrosia maple bowls. Need input on how to finish them, what products to use, methods ect.
Question finishing
Steve ponch
Re: Question finishing *LINK*
Darrell Feltmate
>this is about as contentious an issue as a person can raise but ambrosia maple tends to look good with a finish such as Minwax tung oil.
1) liberally coat the wood using a rag
2) wipe off the extra right away
3) apply a second coat in about 15 minutes. this helps the end grain and other areas that likely absorbed more than the face grain. Wipe off the excess
4) recoat and remove the excess every 8 to 12 hours until satisfied with the depth of finish.
5) after 72 hours lightly sand with 2000 grit wet/dry paper to remove any nubs or dust
http://aroundthewoods.com
I've used most things
steve antonucci
>and I like mineral oil if it's going to be a "user". Easy, renewable, and minimal color change. I will also use beeswax mixed into the mineral oil to finish "users" from time to time.
When they get a little "used" looking, I just grab my old standby rag with the oil/wax mix and wipe on some more...
Steve
>Contentious? I am not contentious!!! But only a fool would use....
Just kidding, Couldn't help it.
I think you want to use something on Ambrosia Maple that will not darken or yellow the wood. I'm guessing you want to keep the nice white color and sharp contrast.
On a keeper/user bowl you want to use a finish that is food safe. While all of the major finishes are food safe are safe after they are finished curing, some of them smell like chemicals for weeks or even months until they cure and that is a real turn off. I personally like lacquer, but it violates the "don't stink" rule.
Walnut oil is great, but my experience is that it pretty seriously yellows the wood. And then there is the nut allergy question. (Versions are available that are safe for those with nut allergies, but why raise the issue?)
Some people say olive oil goes rancid and should not be used. (has not killed me yet)
Some people don't like mineral oil because it never cures and is really and industrial chemical, but it is safe and very clear.
Sunflower of canola oils might be candidates. They smell good and as far as I know, nobody is allergic.
Experiment on scraps to see what you like.
There are as many opinions are as there are people posting.
Also, check out Russ's Corner for good advice. (to your left in red bar.)
Re: I've used most things
>I agree with Steve and Barry on this one. I used a very thin coat of lacquer on my Red Maple ambrosia bowl because the red maple really goes dark with any finish that has a tendency to do that. On user bowls I like a very thin finish because as it starts to wear it doesn't show. This type of user bowl us usually used for nuts, candy and easily cleaned up stuff.
For bowls that will be used for salads and nasty stuff I use walnut oil or mineral oil. I like the Walnut oil but do feel it's necessary to issue the nut oil warning.
I am rapidly becoming a fan of Minwax wipe on Poly. Especially if I follow it up with the Beal system. One or two coats and it's protected and has a low sheen that I can knock down further with 4/0 steel wool if I think it's necessary. 5 or 6 coats and it starts to get very glossy that really stands out when buffed. One reason I'm leaning toward this is that it is a tougher finish than lacquer in some respects. You can buff it really hard and not burn through. It's not as repairable a finish as any of the above but the vast majority of bowls that I sell are usually put on display or used as candy dishes for special occasions so they handle this type of abuse well.
Carole Valentine
>On maple or any wood that I don't want a big color change, I hit it first with a thinned lacquer (50%) which is immediately wiped dry. Once the lacquer is cured, I use my finish of choice - usually one or more coats of Waterlox put on with a cloth then wiped dry. If you want to learn about finishing turnings, I highly recommend Russ Fairfield's Finishing Secrets DVDs. There are 3 DVDs in the set and anything you could ever want to know about finishing turnings (including sanding and preparation) is there.
"Finishing Secrets"
