O.K. I am turning some ornaments starting with 2" stock of Tulip wood for the globe. I have some 2" material that leaves plenty of room to complete the finial. However, it seem wasteful using a 2" blank for a finial. At the same time, if I cut the blank to 1" pieces that seems a bit small for the size globe I like turning. I am drilling a 1/2 hole through the globe and hollowing from there. I do not mean to seem difficult about this but I am wondering if I am missing the big picture. What size blanks do you start with turning your finials?
>The globe can be from 2" stock and the finial can be 1" stock. What can be done is each piece is turned separately, then joined together with a mortise and tenon joint.
>Vince My finials are usually either 3/4" by 4 or 5" long or preferably 1" and 4 to 6" long. I actually start with a blank longer than that. I'll chuck it in my small jaws and turn the long finial. Then when that's done I'll turn a 3/8" tenon on the blank left in the jaws. I'll reverse that and grab the tenon and then turn the finial that's on the top. So my blanks are usually somewhere around 8" long. I have the Vicmarc chuck and the small jaws are about 2" long so this leaves plenty for the upper finial.
>I sort of use the 2" for the top and bottom of the ornament but not all of it. I use the band saw to cut away most of the waste material and use it for other icicles. This is really hard to explain but I have posted a page over on the web site. Just follow the link.
I agree, it would be painful to turn 2" stock down for the finial, especially an expensive piece of ebony or bloodwood!
I've also been hollowing through a 1/2" hole (just turned one in Tulipwood too - beautiful stuff!) and I've been making the finials with 3/4" or 1" stock. I find about 5/8" to 3/4" is fine for my design where it meets the body.
However, instead of turning a globe or flattened globe as I usually see, I like to taper the ends a bit where they meet the finials, softening the transition which otherwise feels abrupt to me. I think this lets a smaller diameter finial works where it might otherwise look too small. Sorry, I don't have a photo at the moment, but the diagram below shows the general idea.
I like the idea that Darrel presents of bandsawing away some of the wood for later reuse. I use that exact method when making magic wands, mostly to speed up the turning. (My waste "blocks" are too thin to turn but someday I'll find a use for a box full of thin strips of exotic woods! - maybe send them to eaglesc?)
It also might look great to make collars of larger diameter than the finial, perhaps of a 3rd wood, or perhaps even make the globe and finials from one wood and the collars from another.
I use a blank for the globe that is about 1 1/2 up to 2". Most of mine are scraps and I either cut them down to whatever I can get or use what I have. I make a little wooden face plate with a Morse taper on it and jamb it in tot eh shaft of the lathe or use a waste block in a chuck. I glue the blank for the globe onto that with CA glue and turn it. I make a pleasant little globe out of it and drill a 5/16" hole into it and hollow it with tools that have a 1/4" shaft.
At this stage, the top of the globe is glued to the block and left a little over sized. The hole for the hollowing may get expanded to 3/8" at the bottom. Once it is hollow, I finish turning the top leaving about a flat of about 5/8", then I drill through that with the 5/16" bit and part the globe off.
For finials I often use scrapes that are about 3/4 or maybe 7/8" square. I have a belt sander and grind a cone on one end that roughly matches the No. 2 Morse taper in the head stock shaft and drive into the shaft with a hammer. I bring the TS up and capture the free end. Turn the icicle, making a little tenon the matches whatever the hole turned out to be. The tailstock gets moved back out of the way when the icicle gets thin. I leave about an inch of the original piece still mounted in the lathe and turn the little cap out or it, again making the tenon matches the hole.
Maybe I should buy another set of chuck jaws. Bummer. And I thought this was working well.
>Sounds fine, Barry. If its working, and you are successful with it, its the (a) right way to go.
I've done this -- the turned Morse taper bit -- but I more commonly spin a bunch of finial and/or icicle blanks between centers, and size a tenon about 1/2" diam by ~1" long on one end with an abrupt step, and grab that end in my 1" Nova jaws in my SuperNova chuck. The jaws seat against the step where the 1/2" diameter meets the larger stock. Usually I use pen blanks or some small square stock I've sawn from 1.5" or 2" stock, or small pieces saved from between the cracks of local air-dried woods.
If I leave a larger blank for too long, or somehow allow it to crack, I usually save finial pieces or small box blanks from between the cracks. When I'm in the spindle-turning mood, I may make a few dozen of these blanks, and just huck 'em in a shoe box, where I'm sure to not find them when I go looking some months later!
My finials tend to be smallish in diameter, as I fuss over the globes and turn them through pretty small holes. If I were turning these for my living I wouldn't have time to fuss over these, and I would have to work much faster, and the diameter of hole and finial would no doubt increase.
As usual, there's no one right way -- whatever works for you...
