>Here is another beaded box in shedua. This has to be my absolute favorite turning wood. It can be a little splintery but since I got my Hunter Tools those sections on the inside where I used to have tearout I no longer have a problem. I started sanding this box at 240 on the inside and that is a big improvement for me. This box is 2 1/4" tall and 3 1/2" in diameter.
>For all the turning I've done, I've made precious few lidded boxes, though I have watched Richard Raffan and Ray Key demonstrate their methods. I am wondering what kind of lid fit you usually go for, Mike. Is it a snap fit or a piston fit or a loose fit?
And, can you use shedua for a box if it isn't dry?
To answer your questions, I usually go for a snug fit that allows the lid to stay on securely but does not require two men and a boy to take it off. It seems most boxes are bought by women and they do not want a fit that is too tight but do want the lid to stay on if the box is inverted. I would guess you could call that a piston fit. I follow Richard Raffan's method of fitting lids. However, the fit does change with changes in humidity and I am always taken aback when a lid that was a little loose in December requires a lot of coercion in July. Of course we have very high humidity levels here.
I try to have all my wood for boxes as dry as the local humidity will permit. Most of the time I am lucky if it is less than 10% moisture. Usually that will not pose a problem as these boxes are turned from end grain and there is overall less expansion and contraction problems with grain in that direction. However, we all know that everything turned round is oval during certain seasons. I have also rough turned many green and air dried blanks and then soaked them in alcohol per the Dave Smith process. After they equilibrate in the shop I usually stick them in the hot water heater closet for a month or two and that usually does the trick. If you turn a box from wood that is too wet I can almost guarantee a lid fit that is difficult to remove.
>Thanks Keith, this wood originates in Africa. It is also known as African walnut and ovangkol. My son sent me a stick labeled ovangkol and it is almost black brown. It is probably a little more dense than our walnut but it can be as splintery. That is why I was having so many problems hollowing/undercutting the rim. Terrible tearout using a hooknosed scraper. The swan neck Hunter Tool I am using just peels away onion skin shavings and if I can control the tool properly I almost don't have any tearout. Definitely a fine finishing tool.
Thanks again for the comments. My wife and son gave me a very large stick of this a couple of years ago for Christmas and I ration it out to make short chubby little boxes. Since then I have stocked up on some more. It is a great turning wood and quite beautiful, I think, when finished.
The box is beautiful, the finish looks perfect, the wood is lovely, and I love the shape. (What is the finish?)
As a registered Mike Stafford box groupie I save copies of your pictures for inspiration. I am accumulating and slowly drying a great quantity of box-sized blanks and have made some boxes but I'm still afraid to touch the better pieces. Should I maybe send you some nice chunks of cocobolo or something so at least some of it won't go to waste?
Where do I sign up for the 3-day Mike Stafford Box-making Course you are about to announce? I have lots of frequent flyer miles and my schedule is flexible!
>John, you are too kind. You should do just as I did when I first started turning boxes. Use cherry, walnut, ash, osage, etc. and make lots of boxes with those. Use those woods to refine your shapes and for practice. I still do that when I am working on a new form and I am afraid to try it on my more expensive pieces of wood. Practice makes perfect.
On this piece, I used and oil/varnish mix. This wood is a little porous on the end grain and I have found I have to apply several coats to get a nice smooth finish. My routine is to mix up oil and varnish in equal parts and thin with mineral spirits. I apply this with a brush on the lathe and allow it to soak in. Then with the lathe running at turning speed, i.e. fast, I buff it dry with paper towels. In between coats I use 7/0 steel wool and white 3M pads to smooth the finish. I try to generate friction so as to heat up the wood. I apply as many coats as the wood needs. I leave the piece mounted in the chuck for a day or so and then buff it out with shoe shine felt and little Renaissance wax. If I do it right I can see myself in it.....LOL.
John, Ed Moore is going to be teaching an ornament and box turning class at John C. Campbell Folk School in August the week of 8/24-30. I have signed up for the class and Ed has graciously offered me an opportunity to assist if enough people sign up to warrant an assistant. He has also said he would allow me to teach parts of the box turning portion regardless of the class size. I am very excited at the prospect of doing this as I dearly love teaching people to turn boxes. I know I can speak for Ed in saying we would welcome you in the class and promise you the best time you have ever had with your clothes on.... I extend that invitation to everyone as John C. Campbell is one of my favorite places in the world to relax and enjoy the company of like minded craftsmen and women.
Thanks for the info.
I got on the website and registered for the course. It wasn't cheap, but when I got to the part that said "three delicious meals are served each day" I knew I was hooked.
>John, I promise you it is money well spent. The school and facilities are well worth every penny and the people that attend are friendly and interesting. If this is your first trip it will not be your last. I am going twice next year.
>...like for you to do an evening demo on box making during my Folk School class March 16~22nd. Can you turn a square one in keeping with the theme of the class? ;-)))
That is wonderful news! I will be delighted to have you in the class and make your acquaintance. I read Mike's comments and he has accurately portrayed what we hope will happen. When I assisted Bob Rosand at JCCFS last May, Bob had me demo a box different from his style one evening and I decided to ask Mike to demo in like fashion. I donated some urchin ornaments to JCCFS and one of the ladies in charge bought one I had on display. She said that after all these years that is the first time she has purchased something from one of the artists. One thing led to another and now we will teach the ornaments and box course in August.
Mike is also working with me to arrange a get-together for box-makers during the Special Interest Night (SIN) at the Symposium in Richmond. Once we get a few more firm commitments from known box-makers for the Q&A session, we will announce the line-up.
