A55 Smoothing Plane
1/2" steel bar
1/2" steel bar
1/2" steel bar
joaz
>Hi all, after watching Escoulen using his bedan tool on Utube, I decided to make on myself and give it a try.
Anyone know where's a good place to by square 1/2" high speed steel?
As always, thanks in advance.
Re: 1/2" steel bar
Re: 1/2" steel bar
Robert Henderson
>McMaster-Carr at mcmaster.com
Re: 1/2" steel bar
Re: 1/2" steel bar
Brian Hahn in SW Wisconsin
>Most industrial supply houses (i.e. McMaster-Carr) don't carry 1/2" square HSS steel stock. You can get 1/2" square lathe cutting bits, but they are only 4" long. However they do carry air hardening and oil hardening 1/2" square stock.
Remember, if you use HSS stock you will need to heat treat it since it usually comes annealed.
The most cost effective source that I have found for larger pieces of tempered HSS is to buy a HSS scraper of the appropriate size and grind it as needed.
Re: 1/2" steel bar
Re: 1/2" steel bar
gtwilkins
>Joaz,
I go to Napa here in Canada and buy key stock, it comes in 12" lengths and sizes from 1/8- 1/2" then I got a piece of heavy 3/4" square tubing and the 1/2" key stock slides in if you ease the corners. I drilled and tapped the square tubing to hold the key stock (2 grub screws) and I shape both ends, Bedan and round nose scraper, I use closed cell pipe insulation on the tubing for grip.
Hope this helps, Trevor
Re: 1/2" steel bar
Re: 1/2" steel bar
>Unless I'm mistaken you can't harden HSS yourself without some sophisticated equipement. You can heat treat High Carbon steel quite successfully and it makes a good bedan tool.
Also if I'm correct the official bedan is tapered and not square. I made mine square. I don't use it often because I'm comfortable with the skew. I should practice with it more. Jean Escoulen does wonderful things with it.
Re: 1/2" steel bar
Re: 1/2" steel bar
Gordon Seto
>The bedans that Jean Escoulen uses are square or rectangular.
The one that has trapezoid shape is English bedan. It is not suitable for what he does. He is using the bedan with the bevel up; the acute angle on the flat side corners would dig into the tool rest. He recommends softening the corners on the square edges.
I think if there is enough interest, probably Doug would expand the Thompson tool line. We will never know.
Gordon
Re: 1/2" steel bar
Re: 1/2" steel bar
Stuart Johnson
>I was watching the video and can't see any difference between the bedan and a good mortise chisel. I have a set of Steve Knight chisels and just might have to give them a go.
Re: 1/2" steel bar
Re: 1/2" steel bar
>Stewart they work fine. I tried one of mine. In fact I fashioned my homemade bedan after that one only I made mine wider and thinner and a steeper angle than my mortising chisel.
Re: 1/2" steel bar
Re: 1/2" steel bar
joaz
>Thanks everyone for the great info. The bordom of winter is making me try something new.
Re: 1/2" steel bar
Re: 1/2" steel bar
Bob Macgregor
>What kind of steel is the key stock? I tried an internet search and key stock (from various suppliers) ranged from cold rolled, hot rolled/low carbon, stainless and unspecified steels (many zinc-coated). Was the Napa key stock HSS?
Re: 1/2" steel bar
Re: 1/2" steel bar *LINK*
Walter Ahlgrim
>look at enco.com item 383-5533 1/2 inch square 8 inchs long 10% cobalt
I made 3/8 beading tool from one seem to stay sharp forever.
Walta
Enco.com
Re: 1/2" steel bar
Re: 1/2" steel bar
Paul Zerjay
>Which is better, oil quench, or water quench? And after the quench, how do you know what temperature to bring it back to for tempering?
Re: 1/2" steel bar
Re: 1/2" steel bar
gtwilkins
>I believe so, it grinds like it is and it was a machinist friend who told me about it. He also makes lathe tools out of crowbars.
I have half a dozen tools I've made out of key stock and it seems to hold an edge just as long as my bought scrapers.
Trevor
Re: 1/2" steel bar
It's soft if you can drill or cut it with a file.
Al Crandall -NW of Indy-
