wood toxicity in finished product
ILYA Zavorin
>Hi,
I am a beginner bowlturner interested in experimenting with as many types of wood as possible. My question is this: what types of wood should be avoided due to their toxicity in a finished bowl or platter? I found several tables listing toxic woods, but they all seem to refer to working with wood rather than to a finished product. Is it true that if a wood is toxic to work with then a bowl or a platter made of it will most likely be unsafe to use in the kitchen? Or does this only apply to the types of wood whose source of toxicity is wood rather than bark, leaves or dust? Thanks much.
Re: wood toxicity in finished product
>You asked a number of questions:
"I am a beginner bowlturner interested in experimenting with as many types of wood as possible. My question is this: what types of wood should be avoided due to their toxicity in a finished bowl or platter?"
Most of the wood toxicity data deals with inhaled dust. As the finished bowls or platters are not likely to be inhaled, I wouldn't really worry about it. Any toxic compounds would have to be leached from the wood (which may or may not be finished) and into the food substance on the bowl or platter. So again, I wouldn't worry about it. I would avoid woods that had been in contact with poison ivy, poison oak and poison sumac - with those you might have a problem.
"I found several tables listing toxic woods, but they all seem to refer to working with wood rather than to a finished product. Is it true that if a wood is toxic to work with then a bowl or a platter made of it will most likely be unsafe to use in the kitchen?"
Dose determines the poison - you wouldn't be likely to get a large enough dose to do anything.
Allen Neighbors
>Black Walnut is said to be toxic, so I keep the shavings out of bedding for hogs and sheep at the Ag farm.
However, I made my wife a set of four bowls from Black Walnut right after I started turning, and we've used them ever since (4 years) and no ill effects.
