Techies & RPMs
Techies & RPMs
Techies & RPMs
Tim GC
>I was wondering if there was any way of measuring RPMs for those with variable speed systems with no RPM readout who may wish to know. I am not a Techie so please don't laugh too much ... I was wondering about things like rigging an old Car Ignition timing light etc. then having found the revs for a certain switch position scribe the switch plate or apply a mark of some description. I do not need it I have a 'guesstimated' chart supplied by the Maker.
Re: Techies & RPMs
Re: Techies & RPMs
Don in Central Illinois
>Speaking of old cars, you could by an RPM meter. A neighbor of mine used to have on, where you put the end of the meter against a turning shaft (in this case a combine) and it would read out the RPM's. Probably be able to find one at farm equipment stores.
Re: Techies & RPMs
Re: Techies & RPMs
>I would have to do some digging but you can get electronic rpm sensors that attach a dot to the spindle and then they read that. I haven't looked for them in years.
Re: Techies & RPMs
Re: Too much information! Experienced....
Jamie Donaldson
>....turners seldom care what the actual RPM's are when working- the lathe/wood/tools/sounds will tell you if you are spinning too fast or too slow. No need to take your eyes off the subject at hand to look at an RPM readout!
Re: Techies & RPMs
Re: Techies & RPMs *LINK*
>Haven't found the one I'm looking for yet but these are interesting. I do agree with Jamie. I don't really worry about the speed but since people always ask at demo's I would kind or like to know.
http://www.reliabilitydirectstore.com/Tachometer-s/43.htm
Re: Techies & RPMs
Bill Hale / The Wood Spinner
>As I tend to turn fast the only time I actually check the speed is when I am sanding. Other than that as said before " Listen, viberation and common sense ".
Good turning and be safe
Bill in CG, AZ.
Re: Techies & RPMs
Tim GC
>I agree, but not everybody is experienced.
Also I only mentioned it as, every now and again, I see a post where someone wonders what speed something was turning at or what speed was recommended etc. etc. etc.
Tim GC
Buzzing and Pondering in the UK
Re: Techies & RPMs
Lan Brady
>Experience is best, but you never have it until 5 minutes after you needed it!
You can buy a photo tachometer at harbor freight. I use one in my real life and find them very accurate. The cost about 60 dollars though.
Good Luck, Lan
Re: Techies & RPMs
Re: Techies & RPMs
Bruce McElhaney, Spring Lake, Michigan
>I've got a PM 3520a with a digital readout on the back that can be converted to rpms. I still don't know the conversion figures. Learning them was on my "to-do" list a few years ago but lost interest. So I just spin the wood till it sounds and cuts right.
Re: Techies & RPMs
Re: Techies & RPMs
Brian Hahn in SW Wisconsin
>Harbor Freight has a hand-held digital tachometer for about $60. Good tachometers cost a couple of hundred dollars.
My lathes all have 3 speeds: too slow -- just right -- too fast.
When needed, I estimate speed from the dial setting and the belt position.
Re: Techies & RPMs
Denis Putland
Re: I believe it is dangerous
Denis Putland
>to recommend that you run your lathe at a certain RPM for such and such a piece.
Every blank you mount in your lathe has it's own peculiarities and for the inexperience turner to mount that piece and turn the speed up to such and such a speed because some demonstrator said so is looking for trouble.
The recommendation to inexperienced turner's should be to always start your lathe at the slowest speed possible and move up from there.
For me personally a RPM indicator on a wood lathe has no value what so ever.
my 2 cents worth. Denis
Re: Techies & RPMs
Wilford Bickel
>I bought a digital IR tach off of ebay for about $30 with shipping for use on the farm and find it of great value with my turning. It comes with a reflective paper you stick on the shaft or spindle or you can do like I did and fix a piece of wood to mount between centers with a piece of the tape on it. I found it very helpful when I go do demos on lathes I don't know as I can get a feel for where the speeds are I am used to on my Delta X5 and Delta midi. Things you get used to such as motor sounds, belt squeals and such that tell you your speed don't transfer to other machines so this helps me find a reference point. Link below - unit is accurate but I don't feel like it is really heavy duty so I try to handle it with care and keep it in the protective case. I've had mine about a year and it is still working great. The only problem I have had is it got turned upside down in my demo box one time and even through the case it depressed the IR light switch and ran the 9 volt battery down so now I remove the battery when I put it in the case.
IR Tach
Re: Techies & RPMs
Re: Techies & RPMs
Tim GC
>Thank you all for your input ... now we have a thread regarding obtaining RPMs (for whatever reason) including links which can be referred to if and when.
Re: Techies & RPMs
Re: Techies & RPMs
Fog Tanner
>The simplest way is to use a mechanical tach. I have 3 plus a photocell version. They will all read to 30,000, but have various ranges so you can read less than 100. For wood lathe the mechanical tach is the simplest, just place the drive against the piece and read the dial. Analog faces are easier to read than digital. I have used digital tachs and hate them.
My Vic has a digital readout so I can check the RPM. The only thing I check is to see if I am exceeding limits for that size wood. I still use the charts from Raffan's book as a guid to maxium safe limits. Lower than that, depends on the wood and what I am doing. I attended a week long class with Raffan this past summer at Craft Supplies in Provo. I used their version of the Vic (mine is Austrlaian) which had no readout. All week RPM was strictly by feel and and Raffans 37 years of experience. I really didn't miss my digital readout a bit, but I don't have Raffan standing in my shop so I still use it at home to make sure I don't go too fast.
Re: Techies & RPMs
Re: Techies & RPMs
adrien Coblentz------WebKitFormBoundaryB5riMd+7AYk
>seems the same as Wil Bickel's EBay one at twice the price.
Re: Techies & RPMs
Free Stroboscope Link *LINK*
Bill Clark
>Tim, I have the same problem earlier this year. After considering the purchase of an expensive Digital Photo Tachometer, I ran across a web posting by a woodturner who designed a stroboscope to measure wood lathe speed. Bingo, just what I needed and it was free. I downloaded the file and attached the stroboscope to a 6� face plate and mounted it on my lathe. Using a standard fluorescent light with magnetic ballast which flashes 120 times per second, I was easily able to record the speed adjustment knob�s position for 10 different lathe speeds in each of the 5 step pulley positions. The link may load slowly but it's still good.
Stroboscope Link
Re: Techies & RPMs
Re: Free Stroboscope Link
Bill Boehme
>I am pleased to see that someone actually read my article and even more pleased to see that it was useful. Since the article was written in 2005, I had "modern" high efficiency fluorescent lights installed in my shop. The sad news is that they operate at a very high frequency (several thousand cycles per second), so until I get a small portable fluorescent light with a magnetic ballast, I can't use the strobe. However, once you determine the speed range of your lathe, you probably won't have much further use for this high-tech piece of equipment. The good news is that the price is right. By the way, the website has a new preferred URL and the link is: http://www.wntx.org/tutorial/strobe.pdf. The old url still works for the time being and probably for the next couple years, but we may eventually do away with the old URL.
Re: Techies & RPMs
Stroboscope lamp
JohnKJordan in East TN
>Bill,
You should be able to use a run-of-the-mill neon bulb to view your strobe disk. These are available at RadioShack and elsewhere for a few dollars and typically run directly on 120V AC house current. Some small plug-in night lights also use neon lamps. I think the flicker is "cleaner" than a fluorescent bulb due to the long decay time of typical phosphors, although not very bright. It should be easy to read in a darkened room.
I have a piano tuning device that uses a neon lamp. The sound of a musical note is picked up by a microphone and used to drive a neon lamp which illuminates a rotating disk similar to the one you made. You adjust the tension on a piano string until bars on the appropriate band of the disk are distinct.
Re: Techies & RPMs
Bill Clark
>Bill, thanks for posting the info and pic of the stroboscope. I downloaded the info, printed out the pic and mounted it on a piece of MDF. Worked great. Once I got my speeds recorded I made a graph and posted it on my speed controller. No need to buy an expensive digital tach. When someone on the forum needed the same info I remembered your post and posted a link. I've attached a picture of the stroboscope on my Woodfast lathe.
Re: Techies & RPMs
Re: Stroboscope lamp
Bill Boehme
>I agree about the neon lamp and have a home built neon lamp strobe. The neon lamp does give a "cleaner" read as you say and the reason is that the electroluminescent phosphors in the fluorescent tube have persistence (that is, they continue to glow even after the voltage in the tube drop below the quiescent value that produces the light discharge from the mercury vapor gasses in the lamp). There are no phosphors in a neon bulb and the discharge voltage of the neon is around 65 volts, so the light is more like short pulses with sharp rise and fall times to give it a definite on and off cycle unlike the fluorescent tube which has a soft on-off pulse waveform. The disadvantage of the neon lamp is that the light level is very low so you need to do this in the dark and get very close to the spinning disk. Another disadvantage is that not everyone would be interested in building a neon strobe light.
Re: Techies & RPMs
Bill Boehme
>Very cool looking set-up. I made the disk the size that it is because it exactly fits the 6" faceplate that came with my Delta 1440 lathe. As best as I can remember, that is the only thing that I have ever used that faceplate for. It is too big for most woodturning purposes.
