Jacobs chuck MT too long
pfduffy
>Solved a little but important problem; tail on my Jacobs chuck was hitting the back end of the MT receiving area on my new Delta Midi preventing full seating. Ground down the tail end about an 1/8in and now that Jacobs mates up perfectly. - - just passing it along. Philip
Re: Jacobs chuck MT too long
>This has been a problem on some lathes. The little tang on the end of the morse taper won't let them seat when the quill is fully retracted. As you found out the solution is to gring it off.
OTOH, some Morse tapers ...
Ed Moore
>on tailcenters are too short. I epoxied a bolt into the end of the tailcenter Morse taper using PC-7 and the protruding head allowed the tailcenter to be ejected when the quill is retracted.
But, in order to use a #3 adaptor on a different tailcenter I had to grind the sides off the end of the #2 Morse taper before it would seat properly in the adaptor.
Ed
George Van
>John, isn�t this a desirable feature when the tang ejects the Morse taper when the quill is fully retracted? I can understand the need to grind the tang if the Morse taper will not seat in the quill but I like it to eject when retracted.
The Jet Midi has same problem, same solution
Brian Hahn in SW Wisconsin
Re: OTOH, some Morse tapers ...
Don in Central Illinois
>Thanks, that is good to know. I have two live centers and both are too short to be ejected when retracting the quill.
Thanks for this solution...
keith zimmerman, Normal, IL
>I bought a #2 MT with a screw adapter to make some jamb/guides such as were discussed in the latest issue of Am Woodturner. I made the first one and discovered the tab on the end of the MT would not allow it to seat in the headstock. After reading what you did for your problem, I'll grind mine down a bit and see if it fits.
Thanks for the idea and solution for a new problem I just discovered.
keith
