DRY PIGMENT FRESCO COLORS
Bill Hale / The Wood Spinner
>HELP I have several colors of dry pigment and want to know how to use them. Mix with what and how to apply so it does not blotch. Sand then color, apply finish or what ?
Thanks Bill
Thanks Bill
Re: DRY PIGMENT FRESCO COLORS *LINK*
keith zimmerman, Normal, IL
>I remember from my studies in Art History back in college that fresco is painting on plaster. I searched on fresco and found that there are 3 distict types of fresco; on wet plaster where the pigment is mixed with water, on dry plaster where the pigment is mixed with a binder such as egg tempra or oil, or on near-dry plaster where the binders were also used. Check the link for more information. You should be able to determine what would be the best binder for your application.
keithz
Fresco Technique
>May be I have the wrong stuff. I bought it as a bowl colorant not to paint a wall ???
Bill
>Is Fresco is a brand name. If that is the case, I have no knowledge of their intended use. I was passing on what I know about fresco paint.
keithz
Fresco
Jorge Castaneda~Downeast Maine
>Hi guys, fresco means "recently prepared" and it is a technique that uses water soluble pigments mixed with a binder, sometimes rabbit glue, applied over fresh plaster used mainly to produce great murals.
If i remember correctly
Jorge
keith zimmerman, Normal IL
>Bill, I have been looking more into this and found that the only references to using fresco pigments is the traditional use, to paint on plaster.
However, I found this site that explains how to mix the paint. I imagine that it could be diluted after mixed and applied to wood just as any other water or oil based pigment. The biggest difference is that fresco pigments are supposedly pure earth-based rather than produced in a lab.
Check out this site. Hope it helps.
keithz
Sinopia fresco recipes
>Sure don't know why I bought this stuff. It does mix with sawdust to make colored fill material.
I guess I will have to play with it and find out how to use it on wood as a dye.
Thanks all
Bill
Stuart Johnson
>Try mixing a bit in some alcohol to see if it will dissolve. If it does use a test piece and try different applications. You might also check the small print on the bottle/package and try to contact the manufacture.
Cyril Griesbach
>Bill, if you can't find a way to use it as a bowl colorant consider mixing it with a polyester resin. Poured into PVC pipe, capped on one end of course, of different diameters to make pen blanks. Or, left to set up in a dixie cup for bottle stopper blanks. Try mixing in some sparkle to enhance it even further. Mixing any additive into the resin will cause the set up time to extend but in any case over night will be plenty and...it does get hot as it cures. The larger the volume of resin the more heat will generate as it cures. The cured product will easily be pushed out of PVC but you can prep the PVC with a silicon spray if you wish.
