Sanding the inside of salt shakers and pepper.....
>mills? Any tips?
Re: Sanding the inside of salt shakers and pepper.....
Why?
Jay in Tx
>No reason to sand the inside, as in the hole where the peppercorns or sea salt goes, to my knowledge. Any finish you put in there is going to get eaten up (figuratively and literally) pretty quickly.
But if you're just dying to get in there and sand to a 1000 grit, then make up a homemade flap sander. Slice a crosshair pattern into the end of an appropriately sized (length and diameter) piece of dowel. Fold up a couple of strips of various grits of sand paper. Put the sandpaper in the dowel (one grit at a time please... ha, ha), chuck dowel in a drill, and flap sand until your heart's content.
Re: Don't want to finish the inside...
>just want to knock down the fuzz from drilling the insides.
Sand paper around a dowel
Brian Hahn in SW Wisconsin
>I use an appropriate sized dowel with sandpaper wrapped around it to knock down the fuzzies in vases. I've done it by hand and with the dowel mounted in a chuck. Usually I tape the sandpaper to the dowel and pad it with a small square of felt or paper towel.
Re: Sand paper around a dowel
Bruce McElhaney, Spring Lake, Michigan
>Sand the bottom, sand the tenon, but sand or finish inside the body? Never! I use a 1-1/16" Bormax to drill through the entire body and it leaves a very clean surface.
Re: Done - works well..
>all I have is a set of Rockler Forstner bits (and an extra 1 1/16" that is equally as inexpensive).
