A55 Smoothing Plane
First try at ornaments
Jim K in Trappe PA
>I decided to give ornaments a try this year. Actually, I decided to make them for Christmas gifts last year, but on Christmas eve when I decided to get started on them, I realized that maybe I would give some other stuff that was already made.
Three maple, three box elder and one cherry, with assorted woods for finials.
Not sure what kind of wire I prefer for the displays - pants hangers from the dry cleaners (already have the hook bent on them, or 12 guage romex (shinier, but a PITA to strip and straighten)!
Jim K in Trappe, PA
Re: First try at ornaments
Allen Neighbors
>Beautiful; stands too. Ya did good, Jim.
Paul Zerjay
>These look great! 1st try huh? How thin are the walls?
Brian Hahn in SW Wisconsin
>Very nice. I wish my first ornaments had looked as good as yours.
>Very nice especially for your first ones. I like to use Brass Brazing wire. You can get it in 36" lengths really cheap at welding supply houses. It's easy to bend and easy to cut and pretty stiff.
Jim K in Trappe, PA
>Thanks for the tip John. Is it a standard width/gauge, or is there a specific size you use?
Jim K in Trappe, PA
Jim K in Trappe, PA
>I would say they are about 3/1000th of an inch thick. They are actually about 3/16. But I would say rather say they are 3/1000.
Jim
eaglesc
>Insert thumbs up smiley here.
Mike Stafford
Mike Stafford
>Well, with success like that I certainly hope you will have a second try. Those are quite lovely Jim.
>Jim I think mine is 1/8" but I'm not sure what the guage is
Very impressive 1st try (2nd, 3rd, ...)
Craig Daymon
Bill Noce
>Very nice are you sure its your first try? I like the different types of finials and icicles. I think its more fun to do different ones instead of all the same style it makes you think of different ideas. Plus you don't get bored. Very nice again.
Steven Antonucci
L to R : I like #5 best
steve antonucci
>Going to be a pretty tree this year...
Steve
Jim K in Trappe, PA
>I've made finials before, but not ornaments. Also, I made a few more ornaments than these that didn't make the cut. I've read that articles on mathematical guidelines for proportions, but have never quite figured them out. I'm learning what is ugly the hard way, and then trying not to do it again!
Jim K in Trappe, PA
Re: L to R : I like #5 best
Jim K in Trappe, PA
>You know, I like the ball, and I like the finial, but I'm not sure about the two of them together. I feel that the ball is a hair too big, or the finial a hair too small. I feel like I got the proportions right on number 7, which was one of my first attempts.
After I started getting an overall feel for what I like (last week, after these were complete), I stopped assembly if I thought they didn't quite work together. Now I have about 6 more balls, and a few finials that didn't work go together, so now I have to start making a few more balls/finials to finish off those pieces.
I wish I had a better eye before I got to the assembly stage!
Jim K in Trappe, PA
a better eye
JohnKJordan in East TN
Jim,
Very nice work on the ornaments. The wood selection and craftsmanship is wonderful. I especially like the two with less symmetrical shapes. This year I too am making ornaments for the first time but I'm not quite ready to photograph.
I also found it a challenge to get the pieces to "work" together, but for me choosing the right color and type of wood made was the most dificult - some combinations were vaguely disturbing while others just felt right.
What I ended up doing: I made a variety of finials from different woods which I could hold up to each completed body. Then I'd make one from the best wood to fit. I found this easier than holding up a raw wood blank and trying to visualize.
wilbur
>Very nice work! Do you mind telling what tools you used for hollowing the ornaments?
Re: wire for display stands
Bill McWhirter
>I use 3/32" steel welding or brazing rods from the welding supply store. They are much stiffer than 12 ga romex and I think that they look better than coathanger wire. They come with a copper-colored coating (rust inhibitor?) which I think looks good. For $5 and change you can get a pound of the stuff which will yield 30 to 40 hangers. Of course, if you are really feeling flush, you can go for the siliconized bronze at $20+ per pound.
To get the bends all alike, I first bent a 1/4" hook on the end with a pair of pliers and then use a jig that consisted of a scrap of plywood with a screw for the hook to catch and a nearby attached circular piece of wood (lathe scrap) for getting the loop.
Jim K in Trappe PA
>Thanks Bill. Good advice all around. I like your idea for a jig. I was using a turned piece to wrap around, but your idea is definitely the way to go.
Jim K in Trappe, PA
Re: a better eye
Jim K in Trappe PA
>You are right on the wood, John. The Box Elder has some vivid red, and with some woods (cherry for example), it just won't work. Very dark woods seem to go with almost everything.
I also go back and forth with myself regarding the ease of conformity and standardized sizes, versus a wide variety. I know if I lock in on sizes that work, it would be easier, but I do like the diversity in sizes and shapes.
Jim K in Trappe, PA
Beautiful!
Mike Cunningham (Cape May NJ)
>I'd never guess these were a first attempt!
Mike
