ADVERTISE HERE - FREE TRIAL
preserving blanks
preserving blanks
preserving blanks
Jim-IL
>Another beginners question. What's the best way to preserve turning blanks until you can get to them?
Re: preserving blanks
Allen Neighbors
>Jim, I coat the endgrain in AnchorSeal, a wax-water emulsion from US Coatings, and store them in a "Refrigerator Kiln" - just an old refer that I drilled holes in the bottom and top for air circulation, and it has a light bulb in the bottom and an inside fan to circulate air. I have two of these, and use the light only when there are roughouts to dry.
Some folks wrap them in paper, some store them in a basement or under the house.
They just don't need a lot of heat, and a lot of wind circulating around them.
JohnKJordan in East TN
>Jim,
If the blanks are green, I coat at least the end grain with a sealer. Perhaps the best is a wax emulsion, such as Anchorseal. This keeps the moisture from escaping too quickly out the ends and causing end-grain checks or cracks. I usually seal the ends and a half inch or so up the sides. Some people coat the entire blank.
Some types of wood are harder to store than others. I have some large chunks of figured maple I coated all over in '03 that still show no signs of deteoriation. OTOH, I coated some american elm earlier this year which still cracked in about two months.
After coating, be sure to keep the wood dry, out of the sun, and away from excessive heat. Storing indoors, such as in the shop or garage may be better than an outbuilding such as an old barn due to potential damage from boring insects. Store where there will be some air movement between pieces, perhaps moving things around occasionally. If two damp pieces stay in tight contact they will likely mold and discolor.
One of the best things to do, if possible, is to rough-turn a green blank right away, then coat with sealer. Rough turning is very quick but you do have to make some design decisions up front. The rough-turned piece will dry and warp but probably not crack even if not turned for a long time. The walls must be left thick enough so all warpage can be cut away. When dry, remount and finish the piece. I've finish-turned blanks that were roughed out and stored for over 10 years.
If the blanks are not green but dry wood, just keep them indoors where they will stay dry and out of the sun.
Barbara Gill, Remlik VA
>For short term storage and small blanks I seal the end grain. For large pieces and those that will be around for awhile I use 2 coats on the end grain and one on the rest. Remember that if there is a knot that is end grain.
Of course the type of wood is always a factor in deciding how to handle the blanks.
Steven Antonucci
A practical approach
steve antonucci
>I agree with other folks about the benefits of Anchorseal. I tend to coat the entire blank or rough out with the following logic.
Let's say that you're in a field cutting on some wood. You've got the gas for your truck to get there, the gas for your saw, and your time spent cutting it into a manageable chunk. If you end coat it, you'll probably be ok with most woods, if you know which ones are the exceptions to the rule.
The cost difference between end coating and completely coating is negligible compared to coming out to a ruined blank that you thought you had. I buy Anchorseal in a 5G pail, and dip the blanks 1/2 way, then the other way. It's messy, but cleans up with water.
Steven
Re: A practical approach
>I read that someone was using one of the pump style sprayers to apply endgrain sealer. I have been thinking about trying that. I tend to be lazy and cut the wood and then just pile it up. If I really like it I'll coat the ends. If I've sawn it into blanks I'll coat all surfaces.
I lose a lot of wood because I can't get too it quick enough. Even sealing the ends doesn't stop the wood from checking if you leave it out in the sun and wind. I don't have a place to store it so I just tend to let it go and assume I'll lose a bunch. I still have a yard full of wood.
I'm thinking about building a sort of covered carport about the size of a small boat. It will go in the back corner of my lot. I'm going to put shelves in the sides so I can store wood off the ground. The roof and trees will keep most of the sun and weather off. Maybe that will improve my odd of keeping good wood. I lose most of it to checks and bugs.
In the Redwood and Douglas Fir country
Jerry Hall
>of northern California and in Southern Oregon the mills have acres of logs with huge sprinklers swinging around keeping all the logs wet, for months, before they saw em up. I have thought of tying a mister or light spray on a battery powered timer to keep my green logs green. When I have been off on trips I have gotten my wife or neighbor to water down my logs and keep them lightly covered with a silver tarp. It has bought me time until I return. Here in the Sierra Nevada mountains summers are DRY and we have 5 feet of winter precipitation. Winters are OK.
The bad news with a summer sprinkler is the wood stays green, but for me that is good. I am getting tired of hauling in all these logs, watching them crack and then next fall giving them to my neighbor for his fireplace. I suppose I could just exercise a little restraint and not get wood I don't need.....It's a disease.
Jesper, Denmark
Jesper, Denmark
>You have a lot of good advice here, but remember one more thing: Split any whole log pieces along the center pith. If you do not, the log will eventually crack/split as the wood shrinks across the grain.
Also, if you coat the whole thing and the wood is wet and green, over time it will start to rot. A little rot is desirable spalting to some. A lot makes it unusable.
As a beginner, you may have more enthusiasme and vigor than turning stock, but as you develop sources for wood, there will be some that lies around for a long time. This is a wonderful situation, but does mean that you have to treat it right from the beginning.
I cannot keep up with turning my supply of wood, but it is a joy to every now and again put your hands on a piece you remember beeing given by a friend many years ago.
total coating
>and completely coating is negligible...
Steve, I thing the issue is not the cost of the coating but how you want the wood to dry.
- With no coating, most wood dries very quickly through then end grain and slowly through sides causing huge shrinkage stresses and severe end cracking.
- With end coating, the wood dries very slowly or not at all through the ends and slowly out the sides, allowing the entire block to dry and shrink slowly just as if it were still in the middle of a long beam.
- With total coating, the entire block dries very slowly or not at all, depending on the coating. As someone pointed out, there is a danger with this method that a wet blank will degrade from being sealed too tightly.
Perhaps success with total coating depends on things like the amount of water in the wood, the temperature, the species, and prior exposure to spores and bacteria. As mentioned, although I generally coat just the ends, I have totally coated entire blanks with success but that was with chunks of highly figured maple wood from logs that sat outside for months - perhaps some of the free water had already drained from the log.
I do see a lot of exotic tropical chunks and squares coated on all sides and they seem to survive. However, I suspect there is a significant moisture difference between a dense chunk of rosewood and a drippping wet chunk of fresh-cut elm. BTW, some of these exotic blanks seem to have been dipped in hot parafin rather than coated with Anchorseal.
Steven Antonucci
I lose half of the wood that I only end coat
steve antonucci
>Like John, I have so much laying around that I worry more about losing it to cracking than rot. My log pile sits in a partially shaded area on the side of my driveway, and gets all the weather and whatnot it can handle. I have a small lean-to that holds some of the wood, but it is woefully inadequate to deal with the expandig pile.
When I coat them, I notice that the bugs leave it alone. If I just dip the ends, I get case hardening cracks on the face grain. I suppose that you could do a much more thorough job prepping the pile, but like I said, I got a lot so the piece I lose end up in the fireplace.
Steve
jeff ferguson
>I use anchorseal to cover rough-turned bowls, but it seems wasteful to use it for blanks if you plan to turn them green. I just use large plastic bags. Most of the time they are only stored for a couple weeks or less, but longer and they just spalt (even better). I put the pieces in plastic bags immediately after chainsawing (including removing the pith) and then only take them out only to bandsaw them round. I have done this with about 500-1000 pieces of wood for blanks up to 20" and have never had one crack, except for the few that were not cut properly when chainsawing.
Bob Macgregor
>And MY kids complain that there is nothing to eat in the fridge!!
Re: Jeff, do you mind...
Allen Neighbors
>telling me/us what part of the country you live in? Thanks...
Maybe that would work better for me in the summer?????
jeff ferguson
>Allan,
I now live in central Missouri (pretty humid) and this plastic bag process works well, but I also did this in Colorado (very dry) and it worked there as well. I do this year-round. My garage goes from 95 degrees and 90% humidity in the middle of the summer to well below freezing and very dry in the winter and this does not seem to matter. The only thing that changes is the rate of spalting. Of all the pieces of wood I have done this with (except for the occasional piece with the pith), I have only had one piece of ash develop a few shallow cracks. If there were no cracks to begin with then they just don�t develop. I have had some hollowform blanks sit for more than six months with no problem.
Let me know if I can answer any more questions
Jeff
