Question about Oneway chucks
jeff myroup
>I have a Oneway strong hold and need a chuck for my jet mini. I was thinking about a Talon. My question: are the jaws interchangable between the two? Thanks for your help.
Jeff
jeff myroup
Jeff
unfortunately No
tek-Brunswick, Ohio
>They each take different jaws. I have two Talons chucks and I'm very happy with them.
Re: Question about Oneway chucks
r thomas
>jeff, you can get an insert to fit your strong hold an use it on the jet . I use a strong hold a delta midi when i need to . the insert is held with 2 set screws takes aout 2-3 min to change . hope this helps
Re: unfortunately No
jeff myroup
>Thanks tek. I kind of thought that was the case.
jeff myroup
>This is probably the way I am going to go. Thanks
Jeff
Brodie Brickey
>Jeff,
I think Hartville Tool has still got a deal going on the body of the Stronghold. You can put WOODNET in the coupon section and they should give you a discount as well.
Regards,
Brodie
>The Stronghold chuck is a bit "weighty" for a Jet mini, IMHO. A Talon is about the right size and weight.
