Cementing glass
Bill Crommett
>What suggestions do I get about cementing glass to wood, such as a wooden handle to a glass mug, or a wood stem to a champagne glass ?
Cementing glass
Bill Crommett
Re: Cementing glass
Don in Central Illinois
>Although, I've never done it, I seem to remember that silicon caulk is what others have used for glass goblets to wood stems. I'm sure others with more info will chime in.
Re: Cementing glass
>I use silicon caulk to glue goblet glass bowls to the wood stems. To glue a wooden handle onto glass I would consider PC-7. Unfortunately that glue is very dark gray so you can't have any blead over. I would grind some little marks on the glass with my Dremel to give it something to grip and then carve a concave surface on the wooden handle to allow more glue to fill the void. Then push this on the glass and carefully scrape away any overfill.
I should see the glass instructor on Monday. I'll try to remember to ask him what they use. I know they use a UV glue to glue glass to glass but I don't know if it works on wood. Of course you need a UV light source to activate it.
E-6000
Barbara Gill, Remlik VA
Re: Cementing glass
Allen Neighbors
>I ditto what John Lucas said about the handle on the mug. PC7 was used to glue a wooden 'step' on a coke bottle. To demonstrate the strength of the epoxy, the man stood on the step. It held.
Re: Cementing glass
>We used PC-7 to glue small rocks onto cynder block walls to use for our rock climbing club. 200 lb men stood on those rocks. After 2 years they were still up. They had to chisel them off when they took over that room for other activites.
Re: John- where would I find PC 7?
Jamie Donaldson
Re: Any Ace or True Value Hdw.
Allen Neighbors
>Or any good lumber yard... or maybe even the borg. It comes in two small cans about the size of a can of wood filler.
>Jamie It usually comes in 2 35mm plastic film cans. Like Allen said I get it at the Ace hardware but my other hardware store carries it also. I've been told that is the same glue they use to glue the reflectors down on the highway. If that's true then it really is strong stuff.
Re: Cementing glass
Colin Spencer
>Bill
I have used both silicone for glass bowls to wooden stems and also fast set epoxy (flexible type). Depending on the amount of movement you think you are likely to get in the wood should drive the type of glue that you use. Living in Europe I am unfamiliar with the ACE glue mentioned by the other responders.
Colin
Re: Cementing glass
Richard Allen
>E-6000 is the glue of choice for the the jewelry craft. I have used it for gluing glass wine glass bowls to wooden stems ro good effect.
Re: A serious question
Russ Fairfield
>You folks have a lot more faith in your glue joints than I do.
Does anyone here really want to depend on a glue joint to keep from having the handle in your hand and a mug of hot coffee in your lap? Or, even a cold drink?? I see these mugs and wine glasses all the time, but I always wonder if anyone really uses them. I know that I wouldn't.
Re:OK, so long as the hot coffee .....
Jamie Donaldson
>.....didn't come from MickeyD's!!!!!!;-)))
don central illinois
>Russ, O ye of little faith!!
A serious answer
Colin Spencer
>Russ
Yes we do use a pair of wine glasses that I have made and no problems so far.
Colin
Bill Crommett
>Don: Don't be too hard on Russ. Skeptics have been the cause of many great progressive movements in history. Note: "The world is not flat", "There has to be a better way than carrying the load on ones back", "Perhaps the steam engine could be made to move stuff faster than horses" and :----"Everything has been invented, so we might as well close down the patent office" and "Hitler has too strong an army, so we might as well concede", "Glue may not stick like we want it to "
For What It Is Worth
>I wouldn't trust a cup of anything that was in a container with glued on handle unless I gripped the container and ignored the handle.
Wine glasses with wooden stems are another thing all together.
Re: Cementing glass
Danny Wells
>Turkey call makers make what are called "pot calls" which are just small flat bowls with a piece of slate, crystal or glass glued on top (its a little more complicated than that). These call makers almost unanimously use Plumbers Goop to glue the slate or glass to the wood because it will hold but is flexible enough to give when the wood moves, and we all know that wood does move.
Plumber's Goop
JohnKJordan in East TN
>Are the various Goops all the same but just marketed with different names?
I've keep a variety on hand (marine, household, outdoor shoe goo, etc) and they all seem to smell and work the same, and have the same curing instructions. I use goop for a wide variety of sealing and adhesive tasks. However, I've never tried Plumber's Goop.
From my experience you can use Goop to glue glass or almost anything else to wood with no danger of it coming apart (as long as there is no oil or wax on the surfaces).
Question
Carole Valentine
>Glass is clear - can you see the glue between the wood and the glass when you look into the bottom of your goblet?
Re: Question
>Yes you can.
