oneway's answere to ,To-Bolt or NotT- Bolt?
eliot d
>Here's what Oneway (Kevin Clay )replied when I asked Oneway the question:
"Bolting it down is best. Adding weight is second best. I am not concerned about the bearings and welds. Would you buy a lathe that was made out of rubber if the bearings would last forever? If you do have an out of balance load on the machine and accidentally run it too fast, bolting it to the floor might prevent the lathe from flipping over."
So it appears that thy do indeed believe that there will be addition stress on the bearings and welds, but they believe the tradeoff is worth it.
Re: oneway's answere to ,To-Bolt or NotT- Bolt?
Bill Hale / The Wood Spinner
>Like I have said before you have to use a little of your brain. Just because you bolt down is no reason you have to run the lathe faster than you should. Start slow, speed up until it starts to viberate and slow a bit. Cut and speed as you can, with reason.
You can damage any tool if you try or are just plain stupid.
Good turning and be safe
Bill in CG, AZ.
I resemble that remark. :)
Bill Neddow
>I am glad someone is checking with the experts on this. Kevin gave me the same answer ten years ago when I bought my Oneway. I bolted it down and realized that I only had half a lathe until I did this. Again, this is not a license to mount wildly out of balance pieces of wood. Reason has to prevail. But the increased stability is amazing.
Bad enough to have a Oneway dancing about. It has a steel tube and can take a fair amount of abuse. But cast iron is very brittle. Seeing a machine with a cast iron base dancing, twisting and bouncing across a room is enough to make me feel a little ill.
