new turner questions
Brent
>Guys, I'm looking at laminating a light colored wood with walnut and turning it. Any suggestions? I know poplar and holly are both roughly the color I'm looking for, but I also know they aren't really that hard - how will they turn when glued to walnut. Thanks for the input.
Brent
Re: new turner questions
Steven Antonucci
I'd use maple
steve antonucci
>I think it's the "norm" and can be almost as white as holly.
Steven
Mike Cunningham (Cape May NJ)
>I often laminate walnut, maple and cherry; as well as padauk, maple and walnut. I've also done bubinga, maple and walnut. All worked fine together.
Mike
Brent
>Thanks guys - if my ideas make it into reality, I'll share them here.
Brent
>I try whenever possible to use woods of approximately the same hardness when I do segmented or laminated work. Maple and Cherry are about the same. Holly is as hard as cherry. Walnut, Mahogony, Poplar are somewhat similar. This is not a hard fast rule it just makes sanding easier because the woods will sand about the same. If you put a real hard wood next to a soft wood the soft wood sands faster and you can get lumps if your not careful. the trick of course is to turn as clean as possible and then sand with a fairly hard backing to keep the ripples out. The more skilled your turning the more you can get away with when using dissimilar woods.
eaglesc
>You didn't say how large of a glue up this will be.
Depending on the size of whatever you are turning, adding CA will"equalize them".
I mix all kinds of woods, grains in any direction.
CA is also a good sealer to prevent color migration between dark and light woods.
JohnKJordan in East TN
Eagle, do you have a favorite type of CA for this? Do you soak the pieces then wipe it off or apply it thin?
I've been using CA more on small turnings lately, to seal pores and under other finishes.
