THE WOODRAT IS BACK!
chuck adapter question
Keith Tompkins
Keith Tompkins
>Hi all, I just bought a (used) Nova Titan chuck, which had been used on a Powermatic 2034. While the spindle size is the same as my General, the adapter is different from my other nova inserts. It has a set-screw to secure it to the shoulder of the spindle, while my others don't, and not as many threads engage when installed as my older adapters as a result of the unthreaded shoulder.
Does Technatool make a special insert for the Powermatic lathe spindle, or have they just changed their design? I can't find anything special listed anywhere.
Also, is anyone aware of a source for a 1 1/8"lefthand threaded insert for nova chucks? For turning outboard....
thanks in advance.
Re: chuck adapter question
Keith Tompkins
Keith Tompkins
>I think that should have read PM 3520. Sorry!
Bill Hale / The Wood Spinner
>Call Craft Supply and ask for a tech. 1-800-551-8876
They sell them and are sure to know.
Bill in CG, AZ.
Carole Valentine
>The set screw is for locking it to the spindle when turning in reverse. You should always use it when doing that. Craft Supplies will tell you that Teknatool has "changed their design" and no longer provides adapters with locking grub screws. That is not true. Teknatool does not recommend using the chuck in reverse with using the screw. If you are going to reverse turn you should have the adapter marked "L".
Carole Valentine
>That should read "Teknatool does not recommend using the chuck in reverse withOUT using the screw."
Keith Tompkins
Re: Edit
Keith Tompkins
>Thanks Bill And Carole...I'll give them a call. My problem is not the set- screw....it's the fact that the area under the screw is unthreaded. It's about a half-inch gap, obviously designed to slip over an unthreaded shoulder before the threads contact. This leaves only a few threads to catch in the General before the chuck seats. That's not good at all.
Does the General have a short spindle?
Brian Hahn in SW Wisconsin
>My Nova insert has a 3/8" unthreaded section under the set screw. That still leaves a full 1" of threads to engage the spindle.
Keith Tompkins
Re: Does the General have a short spindle?
Keith Tompkins
>Hey Brian, Yep, obviously a much shorter spindle than the insert was designed for...I need to find the old-style adapter, or the number for the right insert. Thanks, Keith
Try adapter "Y"
>The "Y" insert is the other 1 1/4" x 8 adapter. Based on Carole's experience, this appears to be the adapter that Craft Supplies carries for that size spindle.
"Y" vs "L"
JohnKJordan in East TN
>Keith, you said 1-1/8", assuming you actually meant 1-1/4" x 8 TPI...
I have both types of inserts for my Jet 1642 and just checked them - the "Y" gives about one more thread than the "L" adapter which may help. I got mine at Woodcraft.
If you can't find one, perhaps someone would trade. I have a couple of "Y" inserts if you want to swap for one.
Also, any good machine shop should be able to make one, but it might be expensive. BTW, a way to add threads to an existing insert is to lay a weld bead inside then drill/ream to size and run a tap through it. It would have to be properly annealed and preheated so it would not crack and warp.
Dick Hines
Dick Hines
>The threads on a PM 3520 is 1 1/4" x 8.
Keith Tompkins
Keith Tompkins
>Thanks guys, and sorry for the confusion. Yes, my inboard is 1 /14 x 8, just like the PM. However, the Outboard spindle is 1 1/8 x 8 LH thread. Don't ask me why they made it that way....I've certainly sent them a list of changes they need to make.
Oneway makes a 1 1/8" adapter that fits both right and left, but haven't seen one for a Nova chuck.
I would like to use the titan both inboard and outboard.
Re: chuck adapter question *LINK*
E.T.
>How about the "Versa-Mount" system from Oneway. The Versa mount plate stays on the lathe spindle and the chuck twists and locks onto this plate. You will need a plate for the inboard and outboard spindles and the chuck and faceplates can be switched from in to outboard as desired. I hope this link works for you, links to Oneway have not been working well today. ET
http://www.oneway.ca/versa-mount/index.htm
Keith Tompkins
Keith Tompkins
>Thanks ET, but I want to adapt the nova to my outboard spindle, I really don't want to buy yet another chuck. The adapter plate won't fit the nova I just purchased. Thanks, Keith
E.T.
>keith, Versa-mount plates and adaptors are pretty expensive anyway. ET
Juergen
>General at one time made a faceplate to be used on the outboard spindle. When I looked at buying one many years ago it was about $US 50-60. You might check with an authorized General dealer. I also seem to recollect that Oneway or Grizzly made some sort of adapter that was threaded both LH and RH on the same adapter or faceplate.
The problem is that 1 1/8"X 8 is a non standard size/pitch. I can't even find a tap with that combination in order to make a faceplate out of wood for vacuum chucking. I've found 1 1/8" x 7. I've had a search on Ebay for over 2 years and have never received a hit. Good luck.
McMaster-Carr has 1-1/8" x 8 taps *LINK*
>Right hand threads only, $48.50
McMaster-Carr
Charles B. Watson
>Treat yourself to a new Powermatic 3520B and the problem is solved!!
INSERT N then, DIY
Technatool lists one insert with that thread but it doesn't say whether it is LH or RH or both. Although there is no hint as to what "UN" means, it is listed as:
CODE: I7NS, DESCRIPTION: INSERT 7, THREAD SIZE: 1-1/8" 8 TPI UN
They also list an unthreaded insert intended to be machined to your specification for odd sizes, something any machine shop should be able to do:
CODE: INNS, DESCRIPTION: INSERT N, THREAD SIZE: Blank. Can be threaded up to 28mm (1-1/8" to match your lathe size.
Keith Tompkins
Re: INSERT N then, DIY
Keith Tompkins
>Thanks all. I've been through the mess of trying to find the 1 1/8" adapter before....I have the oneway adapter, I may machine it to fit the nova chuck as a last resort. I have the outboard faceplate for the lathe as well, but I'd like the ability to use the chuck as needed.
