Re: question, Mike...
Mike Cunningham (Cape May NJ)
>Hi Gary,
I don't get any kind of pocking or open pores, just a smooth finish. On stoppers I sand to 1000 (probably don't need to go that fine) and apply 3 coats of watco. All coats are heavy, in other words the wood is thoroughly wet. I leave it wet for a half hour or so, then wipe it. Sometimes the initial coat is absorbed quickly in which case I apply more. I allow 24 hours between coats and buff after the third and final coat has dried for about one week. There have been times that I've buffed sooner. I use all three Beall wheels.
Maybe you need better surface prep, perhaps sanding to a finer grit or allowing more time before buffing.
I don't know that these stoppers will show up any better than the others.
