Propeller
Propeller
Propeller
Mike Cunningham (Cape May NJ)
>Well not really a propeller but it sure has that effect on the lathe. Pictured is a piece of Brown Mallee burl about 18" X 7 1/2". I'm doing a series of double natural edge pieces and this is number 4. Due to the dimensions, when spinning there's much more air than usual which contributes to a fun time turning. After leaving the solid center area one can just see a very faint ghost and of course an equally faint cut line. You can see the piece here turning at about 500 rpm and if you look carefully at the perimeter you can see the edge.
Mike
Re: Propeller
Propeller spinning
>Actually this one shows it spinning, the other was with the lathe turned off. A careful look should show the ghost edge. You can also see the light that I mentioned in another post.
Mike
Re: Propeller
Steven Antonucci
Bet you don't sand that with the lathe running!
steve antonucci
>One false move, and it's curtains!
I've turned something similar once, but half the size. I don't know that I've want to be in the same room as that, let alone the guy holding the tool!
Steven
Re: Propeller
Re: Propeller
Bill Hale / The Wood Spinner
>Hey Mike Arent those just a thump! Not for the faint of heart.
I posted mine a few weeks back. Just about the sane size.
Looks great.
Good turning and be safe
Bill in CG, AZ.
Re: Propeller
Re: Bet you don't sand that with the lathe running
>Man, you're right, I'd be scared to death (or drunk) to try and sand it while spinning. The bowl portion and an inch or two out from there is not a problem but after that...........
Re: Propeller
Re: Propeller
>Thanks Bill, yes indeed they can be exciting...........
Mike
Re: Propeller
Re: Propeller
Ruth Harding
>Mike, that's a GREAT pic.
r
