Carole Valentine - Light
Mike Cunningham (Cape May NJ)
>Here's a photo of the light that you asked about. It's been on sale at Enco for several months, I bought mine in September and have used it since with nothing negative. It's a low voltage halogen with the transformer located in the base. Unlike others that I've used, this throws no heat, though it does project a goodly amount of light onto the workpiece, a great aid for "gettin' old eyes". You can see the base that you inquired about. The unit is well built (mostly metal) and as you can see in the photo it stays put when placed in position, without further adjustments or tightening, it does have tightening adjustment at each elbow. I drilled and tapped the headstock and mounted using four machine screws though I'm sure you could accomplish the same using 4 goodly sized rare earth magnets. For reference as to extension, that's a shortbed VL300 and a 17" bowl.
As I recall I paid around $85 and feel it was well worth it.
Mike
Re: Carole Valentine - Light
Carol - now in NC Nebraska
>At Indy Fest, Ray was using an LED light for a BBQ. I got one at Lowe's on my way home. Works fine for me. About $20. Magnetic base, goose lamp type neck. Bends where I need it. I also use a shop quartz light form about 6' up on my right and slightly behind me. Just so it doesn't bother my eyes.
Led Light *LINK*
Stuart Johnson
>I just ordered a dual led light from a sewing supply company. I'll let everyone know it it is any good.
Nordic Needle
Carole Valentine
>Thanks, Mike. Looks to be very well made.
