>I finally got some Box Elder the other day when a contractor was clearing the side of the road to put in a sidewalk. He cut up the tree in 16� lengths and stacked them along the side of the road. I was on my way out the door when a friend called and said he found the tree and to come right over. I loaded his Van first and I put a dozen pieces in my truck. That was a good day! I think the trio looks like Christmas to me. The centerpiece is 14�h x 9� dia and the other two are 11 �� H x 6� dia x 1/8 wall. I finished them with water based Poly from General Finishes that Jamie D. recommended. The centerpiece needs a few more coats and polishing. Comments are welcome.
>Seems like your part of the state gets all of the good stuff! I don't see a lot of boxelder in my area, but I did get a bunch of walnut a few days back. Now I just need the time to turn it all.
Sorry, my list is too long already. If I see you at the Richmond AAW next year I owe you a drink.
For Box elder, holly and light woods the water based finishes are the way to go, but they are more sanding work then oil based finishes. On the vessel on the left of the picture I used two coats of the General finish and then two coats of the Velvit. That allowed me to get a glosser shine and get some UV protection. The piece on the right I used just the G.F. finish and it is not as glossy. So I will add two coats of Velvit to it. I apologize for the bad picture. I need to make a larger frugal photo setup for group shots.
>... adjust the camera exposure compensation to a setting of +1 when shooting against a high reflectance background like white. The color balance and contrast will be greatly improved.
As usual, beautiful work! When I saw the biggun' in person it reminded me of pottery glaze (or whatever it's called) streaming down the sides from the opening.
When you find more of the box elder "that's common to our area" save a piece for me!! ;^)
