>I have recently bought an older Rockwell lathe model number 46-111. The question I have is about the tail stock. Are these older models not free spinning or is this old lathe gummed up and in need of cleaning? Any help would be great
>You have a dead center on the lathe, it needs to be lubricated with wax or something to prevent the wood from burning. A live center can be purchased.
According to this, the lathe you have came with a cup type deadcenter and the center pin was removeable via a set screw. This is a "self ejecting" type tailstock. What that means is you make sure the locking handle is loose, item #36 (turn ccw) half turn or so is enough, then turn the round handle on end of tailstock to move the quill #28 back into the tailstock. When the quill is all the way in, it should eject the deadcenter item #25.
I'm not positive but I think this lathe uses Morse Taper 2 for the tailstock. However you need to double check that if you decide to purchase what is called a live center. One that turns and has built in bearings.
>Doug's probably right. They are usually a morse taper that is either self ejecting or if there is a hole in the rear of the tailstock you use a knockout bar to knock it out. If it is a solid piece of steel it's obviously a dead center. If it appears to have a housing big enough to hold a bearing then it's probably a live center that is locked up.
You don't actually have to remove it to tell. A dead center will be about 3/4" in diameter. Most live centers I've seen are at least 1 1/4" or bigger before they go into the tailstock quill
That dead cup center will make an excellent drive center for spindle work (when you put it in the headstock), and a great training tool. Without cranking things down really, really tight, turning square stock to round dowel without stopping the rotation (from the slipping drive center) means you are using sharp tools and good technique. Not to say a production turner wouldn't take much heavier cuts, but a good teaching tool. For beginners and those a little scared of the spinning wood, its also a great safety feature -- if you get a catch, the wood stops, instead of a more explosive result, which can fly off the lathe. It will also limit the amount of finger damage should someone get their finger between the wood and the tool rest -- you can get a bruise, but you won't lose a finger.
