Hollowing tip
Hollowing tip
Hollowing tip
Mark Kauder, Phenix City, AL
>Hi Gang,
Life has been busy, and that limits my time on WC. But I am still managing shop time.
One problem that I run into occasionally, is that after final shaping of a hollow form, I decide that I need to do some more work on it somewhere (usually inside), and dispite using a bowl steady, I am concerned that I may break the bowl off the waste block, or in my segmenting work, I worry that the veneer layers near the bottom will seperate. What to do?
What I do now, is to use bondo to build up around the base of the HF. I make the base thicker, and run it up the sides. This give a great support to the HF, and is very easy to turn off.
It's cheap, too.
Just thought I would pass it on.
Mark
Re: Hollowing tip
Re: Hollowing tip
Allen Neighbors
>Thanks, Mark, that's a good tip... never thought of that to support a form... might work on all sorts of included wood, also, if you keep it out with a little tape. Thanks for passing it on.
Re: Hollowing tip
Bondo??
Tim GC
Re: Hollowing tip
Re: Bondo??
Don Evans
>Hey Tim:
Your comment can be taken 2 ways, one is you are just surprised second is you don't know what BONDO is?
Just in case it is the latter, bondo is a plastic 2 part material made for the body shop industry to repair dents etc on car or truck.
Bondo is a brand name by the way.
Bit of trivia, what was used before these plastic's came to be? Answer is "lead" in stick or bar form and an acetalyne torch to melt it. My dad was a master artist with it.
Don
Re: Hollowing tip
Re: Bondo??
>My high school friend who was a master at restoring cars said he always used lead because it lasted longer than anything else. At least that's what I remember and that was a looong time ago.
I have seen people use the spray foam used for insulation to stabilize pieces that flexed. It would not be as strong as Bondo but would be easier to turn away. don't get this stuff on your hands it won't come off with anything I know of.
Re: Hollowing tip
Re: Bondo??
Tim GC
>Acetone ... nail polish remover ... smells a little like pear drop sweets....
Re: Hollowing tip
Re: Bondo??
eliot d
>A great tip, I would say. I just had exactly the experience you had: I decided to do just a hair of smoothing with a tear drop scraper inside a very thin dogwood hollow form, and it blew up. I didn't go through it; it was vibrating a bit and there must have been a slight catch. Needless to say, it happened very quickly.
Re: Hollowing tip
Re: Bondo??
Tim GC
>Ahhh Body filler 2 part epoxy, well well well I had never thought of that ... Bummer, gave away a 5kg can of it about 6 weeks ago!! Typical.
Re: Hollowing tip
Re: Bondo??
Tim GC
>Oops... I was supposed to say
"For the 'Crazy Foam' on hands problem I use"
Re: Hollowing tip
Re: Bondo??
>Don,
My father learned to do body work back in the 50s, and was a master at restoring cars as well.
Mark
