Ornament hollowing tool....
Mike Stafford
Mike Stafford
>Until very recently I have never hollowed an ornament and had no intentions of doing so until I attended a demo with Dick Sing at the NC Woodturning Symposium. I had the opportunity to examine the tools he used in his ornament demo and actually took some pictures for future reference. In August I am going to take a class and hopefully assist Ed Moore at John C. Campbell Folk School which Ed calls "Ornaments and Boxes".
So to prepare for the course I thought it might be a good idea to try some ornament turning.
When I was watching Dick Sing he used a 1/4" square round nose scraper for a lot of the dirty work on the inside. I had some bar stock and made myself a similar tool. It worked like a charm. Then to finish the inside curves he made a hook nosed tool from an Allen wrench.
I was looking around the shop for a suitable substitute and found this old 1/4" sash mortise chisel that I bought a thousand years ago for some reason. I think it was on sale or being discontinued. Anyway it looked like it could be converted to a swan neck hollowing scraper. Here is what I did with it. It works like a charm and takes a fine edge with a diamond paddle.
Ya'll can laugh and the folks on the Neanderthal forum will probably call it sacrilegious. But it cuts beautifully. Comments appreciated.
Re: Ornament hollowing tool....
Andy Blackwell
>Looks good to me Mike. What ever works.
>I agree. It should work just fine.
Chuck Engstrom
>I think Ed Moore gave a Chesapeake Woodturners demo back in his Maryland days in which he made similar tools bending HSS drill rod in a Harbor Freight bender. Yours looks plenty usable.
Best--
Chuck Engstrom
Brad Vietje
Brad Vietje
>Should work great -- looks like a nice tool. I never understood why people made hollowing tools from square stock. It always seemed just that much more likely to catch on the opening. For real thin HF's and ornament balls, especially those with very small openings, that can lead to new light fixtures as well as ceiling & wall design opportunities !
Safe spinning,
Brad Vietje
Newbury, VT
Mike Stafford
Mike Stafford
>Brad, I am no expert but the method I learned watching Dick Sing was to drill a 3/8" hole through the blank while it was mounted in the chuck. Next the bottom was expanded to 5/8" using the square round nosed scraper. A great deal of the inside is removed using this tool. Then the inside form is shaped to match the outside using this curved scraper. I was surprised at how quickly it went. I actually completed my first ornament without incident. The second one looks similar to an Easter egg shell after peeling....
I guess it is just a matter of being careful and listening to the change in sound as the wood thins. Interesting experience for me.
>Brad I've made and used all sorts of different tools for hollowing ornaments. Square, round or flat doesn't make any differnce when you rub the side of the hole. At least that's been my experience. The real problem is when you go in and come out of the hole. I've blown up more that way than cutting through the side.
Lan Brady
>Mike,
My favorite hollowing tools are made from allen wrench and bent piano wire. Yours does not look any more strange than that!
If it works , use it!!!
Lan
Brad Vietje
Agreed on all counts.
Brad Vietje
>Hi John,
Yup, I agree completely. I sometimes push my limits and work a tool through about the smallest hole that it will fit through, so I've rounded the square edges of any of my square stock tools.
I also completely agree on the entry/exit issues... I think I can still truthfully state that I have never cut through the side of a hollow vessel when trying for a thin wall, (except during demonstrations when I do that purposely to demonstrate the sound changes). BUT, I've had some spectacular explosions from catching a tool going in, or coming out, or from far more stooooopid things, like turning to show off what I've done with a tool in hand, and dinging the outside of a spinning hollow form. DOH ! Sometime I amaze me -- I'm sure I've come pretty close to qualifying for a Darwin Award, and who knows -- with a little more shop time, maybe I'll get one someday... or they'll name a Kevlar face mask in my memory ;~)
Having fun in the snow,
Brad Vietje
Newbury, VT
keith zimmerman, Normal, IL
>This looks like an interesting tool. Could you post a photo of the side profile you have ground on this.
Thanks
keithz
Mike Stafford
Mike Stafford
>Keith, I will try to get a picture for you and e-mail it to you. I don't have a good side profile but it has a 75 degree bevel I am estimating.
Dick Sing's tool, home made from an Allen wrench, had a similar bevel but also had relief along the bottom edge.
